Pimoroni Mood Light - Pi Zero W Project Kit, internet-connected
SKU 114991410
39.00
10 Available
$39.00/ 1pcs+
A beautifully modern Mood Light that'll look great on your bedside table, bookcase, or desk, and it's internet-connected!
Our Mood Light Kit has everything* you'll need to build a sleek looking light that evokes a real pendant light, and uses our Unicorn pHAT board with 32 programmable RGB Neopixel LEDs. Set it to a single colour, have it fade through all the colours of the rainbow, or harness the built-in wireless LAN on the Pi Zero W. It'll take around 30 minutes to assemble everything** (check out our assembly guide for details).
Mood Light uses our popular Unicorn pHAT board, with 32 programmable RGB Neopixel LEDs, giving you a veritable rainbow full of colour possibilities. The stand cleverly mounts the Pi Zero W and Unicorn pHAT at just the right angle to cast the light through the pendant light cutout and diffuse it beautifully.
The built-in wireless LAN on the Pi Zero W opens up a wealth of opportunities: connect it to your Twitter feed and track the mood of your recent tweets, or fade through the sunset and sunrise colours once you've pulled the daily sunset/sunrise times from your favourite weather server.
Note that this is a soldering project.
  • 8x4 matrix of programmable RGB Neopixel LEDs
  • 3-layer white and yellow pendant light stand and diffuser
  • Pi Zero W with single core CPU and built-in wireless LAN and Bluetooth
  • Adaptor kit
  • 50cm USB A to micro-B cable (power your Pi from an existing charger or computer)
  • Python library
  • Female and male headers require soldering
Technical Details
Dimensions145mm x 90mm x 40mm
WeightG.W 287g
BatteryExclude
Clear frosted front layer1
Yellow lamp fitting insert1
White middle layer1
White back layer1
White leg retainers2
White legs with rubber feet attached2
M3 white nylon bolts and nuts6
M2.5 white nylon bolts and nuts4
Pi Zero W1
Unicorn pHAT with 32 programmable RGB Neopixel LEDs1
Male and female 2x20 pin headers1
White and yellow pendant light stand and diffuser1
50cm USB A to micro-B cable1
USB A (female) to micro B (male) adaptor1
Mini to full-size HDMI adaptor1
Sticker sheet (personalise your Mood Light!)1
Comes in a reusable kit box1
ECCNERA99
HSCODE9023009000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 114991410
    $39.00
    10 Available
    $39.00/ 1pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
