the AI Hardware Partner
Toggle Nav
Loading...
Polymer Lithium Ion Battery - 2200mAh 3.7V
Rating:
100 % of 100
This is a light weight, high energy density polymer lithium battery
$9.90
Out of stock
This is a light weight, high energy density polymer lithium battery. It outputs a nominal 3.7v at 2200mAh, including built-in protection against over voltage, over current, and minimum voltage. It comes terminated with a standard 2-pin JST connector-2.0 mm spacing between pins.
Please do not attempt to charge these with anything but a specialized Lithium Polymer charger.
Recommended chargers for 3.7V polymer lithium battery:
  • Excellent long-term self-discharge rates
  • Robust power source under extreme conditions (-25 to 60°C)
  • CE, Rosh, UN38.3 compliance
Specifications
  • Charge voltage: 4.2V
  • Nominal Voltage: 3.7V
  • Nominal capacity: 2200mAh @ 0.2C discharge
  • Minimum rated capacity: 2100mAh @ 0.2C discharge
  • Max. Charge current: 2.2A
  • Max. Discharge current: 3.3A
  • Cell weight: Approx.42g
  • Dimension: 53mm x 51mm x 8.5mm
  • Connector type: JST2.0mm
  • Wire length: 60±5mm
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 41g
Battery Lithium Cells / Batteries loose (bulk) UN3480-PI965
HSCODE 8507600090
  1. Product Quality
    100%
    By
1 Item
Show per page
