Polymer Lithium Ion Battery - 2200mAh 11.1V
  • Polymer Lithium Ion Battery - 2200mAh 11.1V
SKU 313020001
This is a good Li-po battery for projects like small robotics and radio-controlled projects
This product contains battery, might applys to shipping constriction.
$16.90
DISCONTINUED
This is a good Li-po battery for projects like small robotics and radio-controlled projects. With high discharge rates and big capacity, it can nicely feed the stomach of your projects. This high power output battery has very special internal structure, which requires dedicated balance charger to charge. We suggest IMAX B6 or Li-Poly Battery Charger as a suitable mate.
The battery of lower voltage is also available, click here to get it.
Note: Short circuit and overtax are forbidden due to absence of built-in protection circuit.
  • CE Certificated
  • 7.4V 2- cell pack
  • Rated charge current 1A
  • Max. charge rate 5C
  • Continuous discharge rate 30C
  • Burst discharge rate 60C
  • JST-XH charge plug
  • T-plug female discharge connector
  • Dimensions: 105mm x33mm x17mm
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
The description says"Dimensions: 10.5mm x 3.3mm x 1.7mm". This seems unreasonable to me. Shouldn't it be centimeters (cm) instead of mm?
on Oct 19,2016
Replyupvote ()
Sorry for the careless and thank you for your kindly feedback, it is CM!
on Oct 20,2016 10:48 AM
Replyupvote ()
Reply
See More
View History
Recommendations
SUBMIT
Invalid email address.
