RFbee V1.1 - Wireless arduino compatible node
  • RFbee V1.1 - Wireless arduino compatible node
SKU 113050002
The RFBee is a RF module providing easy and flexible wireless data transmission between devices
Free Express Shipping on Orders over $200!
$19.50
5 Available
Qty:
This field is required
ADD TO CART
$19.50/1pcs+
$17.55/10pcs+
$16.58/20pcs+
$15.60/50pcs+
The RFBee is a RF module providing easy and flexible wireless data transmission between devices. It is based on a AVR Atmega168 working as a fully functional Arduino connected via SPI to a TI CC1101 RF transceiver.
  • Range: indoor/Urban: up to 50m; Outdoor line-of-sight: up to 120m;
  • Receiver sensitivity: -95dBm
  • RF data transmission rate: 4,800bps; 76,800bps
  • Working frequency : 868MHz & 915MHz
  • Communication type: Point to Point, or Point to Multipoint.
  • Easy-to-Use serial interface and rich extendable ports
  • Easy-to-Use AT command: Set working mode, Serial Baud Rate, etc.
  • Open source hardware and firmware
  • Socket compatible with the Xbee, so you can plug it into any Xbee socket as a quick replacement.
Note
only the Rx,Tx, VCC, GND pins are identical to the Xbee. RFbee will not communicate with Xbee, so RFbee need to be used on both ends of the wireless connection.
Documents
Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
Does this module require the wireless shield as well?
on Oct 19,2016
Replyupvote ()
Hi, it's possible get the battery status as Seeeduino Stalker?
on Oct 19,2016
Replyupvote ()
yes you can. Normally this problem is depended on your program.
on Oct 20,2016 10:47 AM
Replyupvote ()
Reply
0
An Arduino Uno has PWM capability on DIO pins 3,5,6,9,10,11. On the RFBee, only Arduino DIO pins 5,6,9 are available (PD5, PD6, PB1). Pins 5 and 6 work fine, but pin 9 does not seem to function. If I analogWrite(9, 0), it will go low. If I analogWrite(
on Oct 19,2016
Replyupvote ()
Yes, the power_timer1_disable() was staring me in the face and I didn't notice it. I commented it out and then the PWM worked fine. Thanks!
on Oct 20,2016 10:46 AM
Replyupvote ()
Reply
0
Is there any RX/TX pins on that module? I mean a pin that a can communicate with an Serial GPS??
Thanks
on Oct 19,2016
Replyupvote ()
Hi.You can use software serial port to communicate with GPS.
on Oct 20,2016 10:45 AM
Replyupvote ()
Reply
0
I have successfully flashed one of my two (2) RFBEES, the first one has worked multipul times(using the reset method), but with the other, i have received multipul AVRDUDE errors (avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0xf
on Oct 19,2016
Replyupvote ()
Hi.You can download the library(not the new one) on our wiki,may it can solve your problem.
Replyupvote ()
Reply
0
During the last months playing around with the RFBee I many times wished that there where two pin headers connected with GDO0 and GDO2 pins of the CC1101. Especially in modes that don't use the internal package handling of the CC1101 (synchronous/async
on Oct 19,2016
Replyupvote ()
Okay, thanks for your feedback , we will consider it in the next revision of this module.
on Oct 20,2016 10:44 AM
Replyupvote ()
Reply
See More
View History
Documents
Best-sellers
SUBMIT
Invalid email address.
