JavaScript seems to be disabled in your browser. For the best experience on our site, be sure to turn on Javascript in your browser.
Shop
ROCK Pi 4 Model C is a Rockchip RK3399 based SBC(Single Board Computer) by Radxa. It can run android or some Linux distributions. It features a six-core ARM processor, 64bit dual channel 3200Mb/s 4GB LPDDR4, up to 4K@60 HDMI, MIPI DSI, MIPI CSI, 3.5mm jack with mic, 2.4/5GHz WIFI, Bluetooth 5.0, USB Ports, GbE LAN, 40-pin color-coded expansion header, RTC. Also, ROCK Pi 4 model C supports USB PD and QC powering.
Who Viewed This Also Viewed
ROCK Pi has a modern and powerful hexa-core ARM-based processor, RK3399 inside, it offers significantly improved performance versus other popular SBC boards. All models are equipped with LPDDR4 3200Mb/s RAM. Furthermore, you can add high-performance eMMC modules, to boost all applications performance.
ROCK Pi features maker friendly expansion options, including a 40-pin GPIO interface that allows for interfacing with range inputs from buttons, switches, sensors, LEDs, and much more. ROCK Pi also features a Gbit LAN for the network, with dedicated bus and controller, it works without latency under heavy load network applications. Onboard 802.11 ac wifi offers 2.4G&5G WLAN connectivity. With Bluetooth 5.0, ROCK Pi benefits-improved Bluetooth speed and greater range. ROCK Pi also features one USB 3.0 host and one USB 3.0 OTG ports, each 5Gbps/s, working independently. The USB 3.0 OTG can work as a USB device such as Android ADB or USB gadgets. A hardware switch is provided for OTG mode switch.
ROCK Pi supports mainstream AI stack with GPU acceleration. Furthermore, a dedicated hardware NPU accelerator coming up next for ROCK Pi will boosts complex Machine Learning algorithm and reduce the power. Industrial standard MIPI CSI connector makes it easy to connect existing cameras to ROCK Pi and ROCK Pi also supports industrial standard MIPI DSI for LCD and touch screen. With the hardware-accelerated algorithm, it's great for Computer Vision application, Robotics and much more
MIPI DSI 2 lanes via FPC connector
Any two of HDMI/DP/MIPI DSI can work at the same time, support mirror mode or extend mode.
1 x ROCK PI 4 Model C
Note
If you are looking for open source SBC for commercial and industrial needs. Seeed provides customization service based on BeagleBone series boards. Seeed Studio BeagleBone® Green(BBG) and Seeed Studio BeagleBone® Green Wireless (BBGW) provide more stable industrial deployment scenarios.
