JavaScript seems to be disabled in your browser. For the best experience on our site, be sure to turn on Javascript in your browser.
Shop
This is an 8-layer acrylic enclosure with two RGB fans that provide better shell protection and better heat dissipation for Raspberry Pi clusters, Raspberry Pi NAS servers, Jetson Nano clusters, and disk array clusters.
Who Viewed This Also Viewed
It can easily fit Raspberry Pi 4B /3B+ /3B, 2.5-inch, and 3.5-inch hard drives and Jetson Nano.
The long fixing screws are designed with flat head screws, which is easy to install and the fool-proof design of the positioning holes can prevent you from having trouble during installation.
Also, the large 120mm RGB fans are driven by 5V, which can be directly powered by a Raspberry Pi, and they have a colorful halo effect when running.
Note
If you want to make better use of space, you can place the Raspberry Pi on one side of the bracket, and on the right side, you can place other small equipment, such as UPS power, etc., and it can also be used as a place for cables.
Raspberry Pi Smart NAS Cluster
Jetson Nano AI Deep Learning (Machine Learning) Cluster Storage
