seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Raspberry Pi 3.2 Inch Touchscreen Display w& 8 extend headers
      • Raspberry Pi 3.2 Inch Touchscreen Display w& 8 extend headers
      SKU 104110003
      This is a Raspberry Pi Display specially designed for Model B+
      $29.95
      DISCONTINUED
      This is a Raspberry Pi Display specially designed for Model B+. It features 3.2"TFT LCD and resistive touch panel, 65K colors and 320x240 pixel resolution. The display integrates LCD driver ILI934 and touch driver XPT2046, communicating with Raspberry Pi through High Speed 48MHz SPI connection. With the touch panel, you could play the Raspberry Pi without the need for a mouse.
      It's very easy to setup, without the need for a cable or extra power supply, it can be directly attached onto the Raspberry Pi. We have packaged a system image with the LCD driver for you, what is based on the official Raspbian Operating System, so you don’t need to download driver with the step and step instructions. The system image file can be found from the attaching CD-R. After the image installation, power on the Raspberry Pi, it may take 20 seconds for loading the driver, and then the LCD will work.
      There is a little difference between Model B+ and Model B, but this display also works with Raspberry Pi B, if you don't mind the display will cover the USB and Ethernet ports.
      FEATURES
      Compatible with Raspberry Pi B+ and B
      Supports Raspbian Operating system
      65K colors and 320x240 Pixel Resolution
      Powered directly off Raspberry Pi
      Display full GUI output / primary output
      25 Frames per second
      Integrated ILI9341 TFT LCD Driver
      Integrated 4-wire Resistive Touch Panel and XPT2046 Driver
      Wiring
      Display
      Raspberry Pi
      Remark
        GND
        GND
        VCC
        5.0V
        RESET
        GPIO2
        Reset
        LED-A
        3.3V
        KEY1
        GPIO1
        Button
        KEY2
        GPIO4
        Button
        KEY2
        GPIO5
        Button
        LCD_DIN
        MOSI
        LCD_CLK
        SCLK
        LCD_CS
        CE0
        LCD_RS
        GPIO3
        Command/data
        TP_DIN
        MOSI
        Touch Controller
        TP_OUT
        MISO
        TP_CLK
        SCLK
        TP_CS
        CE1
        TP_IRQ
        GPIO0
      PART LIST
      Raspberry Pi 3.2"Touchscreen Display x1
      Resistive Touch Pen x1
      CD-R x1 (System Image Files and Software Included)
      DOCUMENTS
      Raspbian System Image - Preinstall LCD Driver, Plug and Play
      Image Installation Guides
      Q&A - Instructions for 3.2"Touchscreen Display
      ILI9341 and XPT2046 Datasheet
      See More
      $50 Featured List
      $100 Featured List
      $200 Featured List
      Don’t miss out!
      Reviews
      See More
      Questions and Answers
      SUBMIT
      See More
      View History
      Recommendations
      SUBMIT
      Invalid email address.
