the AI Hardware Partner
Toggle Nav
Loading...
Raspberry Pi Compute Dev Kit - BCM2835 32Bits ARM
The new Raspberry Pi Compute Module Develop Kit enables advanced design engineers to use the Compute Module IO Board and Compute Module along with the downloadable board schematics to create their own PCB design and harness the power of the Raspberry Pi i
$288.00
Out of stock
The new Raspberry Pi Compute Module Develop Kit enables advanced design engineers to use the Compute Module IO Board and Compute Module along with the downloadable board schematics to create their own PCB design and harness the power of the Raspberry Pi into their own embedded application.
Feature:
  • ARM1176JZF-S
  • BCM2835
  • 32 bits
  • Flexible & Rapid Prototype Development
  • Small & Powerful
  • Large Range of GPIOs & Interfaces,
  • On board 4GB eMMC Flash memory
Specification:
  • Broadcom BCM2835 CPU 700MHz
  • SODIMM sized (6.5cm by 3cm) Raspberry Pi board
  • 512MB RAM
  • 4GB eMMC Flash memory
  • micro USB connector type B
  • 2 x CSI ports for camera boards
  • 2 x DSI ports for display boards
  • Full size HDMI port
  • Micro USB power connector
Package Include:
  • 1x Raspberry Pi Compute Module IO Board
  • 1x Raspberry Pi Display & Camera Adapter
  • 1x 5V Micro USB Power Supply
  • 1x Micro USB Data Cable
  • 1x 4 x jumper wires
Resource
Dimensions 0mm x0mm x0mm
Weight G.W 410g
Battery Exclude
