Raspberry pi B+/2B HIFI DAC
SKU 114990303
23.99
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
HIFI DAC+ Digital Audio Card Pinboard designed For Raspberry PI 2 Model B +, adopt high-end DAC chip PCM5122 of TI Company.
You can setup internet HIFI player by Volumio or xbmc system.
  • Using PCM5122 DAC chip from Burr-Brown Corporation, with 32-bit, 384kHz PCM interface, I2S data format.
  • Dual Gold-plated RCA jacks, keep fantastic conductive properties!
  • Gold-plated 3.5mm line out jack (Not for your earphones, it's for audio power amplifiers only!)
  • Special designed power source system by U-geek, isolating DAC power source part from the Raspberry Pi power source system,   keeps the current noise away, gives you crystal clear sound.
  • High quality U-geek Designed PCB - check out our other products and you'll know what I mean!
  • Please check out the following resisters and capacitors that we used on this DAC+ -
  • we choose the best quality components that are usually used on professional HiFi devices
  • and that's where your good audio quality comes from:
  • VISHAY resister (made in Czech)
  • ELNA RBP2 capacitor (made in Japan)
  • WIMA MKS2 capacitor (made in Germany)
  • ERO KP1830 capacitor (made in Germany)
  • Nichicon FG series capacitor (made in Japan)
  • IR remote interface
Technical Detailes:
1.Sampling Frequency:384KHz
2.Resolution (Bits) :16-32
3.Digital Audio Interface :I2S
4.SNR :120dB
5.THD:-93dB
6. Dynamic range :112dB
7.Supports Raspberry Pi B+, Raspberry Pi 2 Model B
Package Weight: 0.03kg (0.07lb.)
Package Size: 10cm x 10cm x 10cm (3.94in x 3.94in x 3.94in)
1 x HiFi DAC+ Module
HIFI DAC+ Digi+ in Volumio
HIFI DAC+ Digi+ in XBMC
HIFI DAC+ Digi+ in Koli/OpenElec
HIFI DAC+ Digi+ in RuneAudio
File:PiFi User Guide.pdf
Download
http://volumio.org/
http://raspberrypiwiki.com/download/HIFI/
Technical Details
Dimensions120mm x 80mm x 24mm
WeightG.W 49.60g
BatteryExclude
Raspberry pi B+/2B HIFI DAC1
ECCNNot Available
HSCODE8518900090
Reviews
Questions and Answers
SUBMIT
0
This board is not compatible with Pi 3 Model B V 1.2? Thanks
on Sep 06,2018
Reply upvote ()
Hi there, it only supports Raspberry pi B+ and 2B. thanks.
on Sep 06,2018 16:02 PM
Reply upvote ()
Reply
0
As I see C14 omitted on my board. Is it OK?
on Jul 04,2018
Reply upvote ()
Hi, there~ don't worry, it's ok
on Jul 04,2018 09:35 AM
Reply upvote ()
Reply
    View History
    SKU 114990303
    $23.99
    OUT OF STOCK
    $23.99/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
