Raspberry Pi B+&2&3 Acrylic Enclosure
Rating:
88% of 100
3mm acrylic Light and easy to transport good heat dispersion Compatible with Raspberry PiB+/2.
$2.95
Out of stock
  • 10+: $2.66
  • 20+: $2.51
  • More
  • 50+: $2.36
  • Less
It is a good plastic box for Raspberry Pi, which can protect it with one of these snazzy plastic enclosures?. These cases protect the Raspberry Pi from things like rogue wires that might short it out while still allowing full access to the board! Simply snap the RPi into the bottom half of the enclosure, then snap the two sides together.
The enclosure provides slots to access the peripheral header, USB ports, Ethernet, SD card, HMDI, composite video, audio, CSI and JTAG connectors as well as feet and vents to ensure the board gets proper cooling and plus-shaped wall mounting slots. All of the status LEDs on the Pi are visible through the case thanks to light pipes embedded in the design. This is a really slick case and once you've gotten your hands on a Raspberry Pi, you'll want to snag one of these to put it in!
  • 3mm acrylic
  • Light and easy to transport
  • good heat dispersion
  • Compatible with Raspberry PiB+/2.
  • Case size: 95x65.5x34.5mm
Compatible with
Dimensions 0mm x0mm x0mm
Weight G.W 65g
Battery Exclude
ECCN ERA99
HSCODE 3923100090
UPC 841454100164
Customer Reviews
  1. Easy to setup and use.
    Rating
    100%
    All connectors are easily accessible and the board is accessible and protected.
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    100%
    Good received
    Review by
    Posted on
  4.
    Rating
    60%
    Review by
    Posted on
  5.
    Rating
    80%
    Review by
    Posted on
Product Faqs
Sort by
