ReSpeaker Mic Array v2.0
SKU 107990053
69.00
15 Available
$69.00/ 1pcs+
$62.10/ 10pcs+
The ReSpeaker Mic Array v2.0 is a hardware-based solution for creating or adding voice-interface to your projects. The board is a far-field microphone array device capable of detecting voices up to 5m away even with the presence of background noise. The onboard hardware-enabled algorithms are powered by the XMOS XVF-3000.
Several improvements have been made since the original ReSpeaker Mic Array v1.0. The first thing you may notice is the reduction of microphones. With the improved performance of the XMOS XVF-3000, including the improved full duplex AEC, we’ve been able to deliver increased performance with fewer microphones, and thus a lower cost.
We’ll be offering our customization services for this device in the future. Contact iot@seeed.cc to learn more.
Pick Up Voices From Far Away
  • Far-field voice capture enables you to capture and understand requests from up to 5m away
Focus On The Right Voice
  • DoA allows the device to know the direction of a source
  • BF allows the device to focus only on sounds that come from the target direction
  • Ignore background noise and chatter through NS
Improved Voice Audio Quality
  • Reduces environmental voice echo with de-reverberation
  • Remove current audio output with AEC
If you think this sounds good, great! But let us prove it. One of our engineers recorded himself speaking over music being played. Hear for yourself how it really sounds with our full-duplex AEC demo below.
This is the raw data captured from the environment. There is no editing on this channel. Our engineer played some music from the device and spoke at the same time.
Channel 1 Audio:
This is the music that the device was playing at the time.
Channel 5 Audio:
This is the end result after processing. The music was almost completely removed resulting in a high quality voice input.
Channel 0 Audio:
When it comes to development we believe you should have as many options as possible. The ReSpeaker Mic Array v2.0 is able to work with most modern Linux, macOS, and Windows systems*.
*We do recommend Linux for firmware updates.
We are working hard to ensure the setup is simple. The documentation on our wiki will help you get up and running quickly, and should unknown issues pop up our tech support team is ready to help. You can ask questions in our ReSpeaker forum, which is checked daily. You can also check out the GitHub for more support.
• XVF-3000 from XMOS
• 4 High Performance Digital Microphones
• Supports Far-field Voice Capture
• Speech Algorithms On-Chip
• 12 Programmable RGB LED Indicators
• Microphones: ST MP34DT01TR-M
• Sensitivity: -26 dBFS (Omnidirectional)
• Acoustic Overload Point: 120 dBSPL
• SNR: 63 dB
• Power Supply: 5V DC from Micro USB or Expansion Header
• Dimensions: 70mm (Diameter)
• 3.5mm Audio Jack Output Socket
Applications
• USB Voice Capture
• Smart Speaker
• Intelligent Voice Assistant Systems
• Voice Recorders
• Voice Conferencing System
• Meeting Communicating Equipment
• Voice Interacting Robot
• Car Voice Assistant
• Other Voice Interface Scenarios
ReSpeaker Mic Array v2.0 - DOA & AEC Test
Technical Details
Dimensions70mm x 70mm x 13.30mm
WeightG.W 70g
BatteryExclude
ReSpeaker Mic Array v2.01
ECCN3A611.y.6
HSCODE8518900090
Reviews
Questions and Answers
SUBMIT
0
What do I need to make an audio recorder? Just the mic array or do you need the core as well? What are their different functions? Thanks.
on Jun 06,2018
Reply upvote ()
Hi Andrew~ The mic array need a upper computer (such as Raspberry), it only can pick up audio. The core can work as a recorder, you can consider the core as the array + Raspberry. Regards
on Jun 07,2018 09:33 AM
Reply upvote ()
So in your demos where it separated the audio from the background noise, was that done on the V2 array or was that done on a separate computer? I need clean processed audio to come out of that jack on the array, is that what it does?
on Jun 19,2018 01:25 AM
Reply upvote ()
Oh also is it possible to unsolder the mics so I can move them into other locations? Say within 5-10ft? Thanks!
on Jun 19,2018 01:35 AM
Reply upvote ()
Hi,Andrew- the method of noise reduction was intergrated in the board, which included circut and algrithom, thanks!
on Jun 21,2018 16:42 PM
Reply upvote ()
you'd better not do that :)....
on Jun 21,2018 16:44 PM
Reply upvote ()
Why? I can do it properly.
on Jun 22,2018 02:49 AM
Reply upvote ()
on Jul 09,2018 15:07 PM
Reply upvote ()
The build-in algorithms needs to know the geometry of the mic array to work well
on Jul 26,2018 10:19 AM
Reply upvote ()
Reply
2
I use the ReSpeaker Mic Array v2.0 in my intelligent speaker box,but the voice recognition function is so poor,specially when playing music.I tried Tuning but it didn't work~what can I do?
on Jun 05,2018
Reply upvote ()
Hi there~ Could you please tell us more detail, a short video will be better. You can email us: ### techsupport@seeed.cc ###
on Jun 05,2018 15:50 PM
Reply upvote ()
Thanked your reply:) The truth is, I didn't plug the speaker into the 3.5mm Headphone jack of the mic array,but into the mainboard of my intelligent speaker box. Is that the problem? I'm also confused that when I tested according to the AEC example, the audio of channel 0 was not good and there was still a lot of music :(
on Jun 05,2018 16:54 PM
Reply upvote ()
Hi there~ For the AEC, The Echo Cancellation Channel is output buy the 3.5mm headjack. So if you do not use the 3.5mm jack, the mic array can not get the echo channel, there for the channel 0 is not good. Regards
on Jun 06,2018 09:33 AM
Reply upvote ()
Hi,Thanked your reply~I pluged my speaker into the 3.5mm jack,it worked good with PC,but can not play any voice with my speaker box used android 6.0 system.when used tinyplay,it showed Sample rate and Bitrate is not ok.Could you please give me a firmware that support 16bit/44100hz?
on Jun 12,2018 09:06 AM
Reply upvote ()
Hi, friend- sorry, we now not offer the tech support about andriod..., Regards!
on Jun 21,2018 16:36 PM
Reply upvote ()
Hi,thks,After much effort,now it works well with my andriod system,except voice recognition is invalid when the music voice is a little bit louder,and I saw the new version with fixed gain in github,does it means AGCGAIN? Would it be better for me to use the larger gain version?
on Jun 26,2018 11:42 AM
Reply upvote ()
Reply
0
We have now three ReSpeaker Mic Array v2.0: 1. works for some time with Linux and was death after using it with Win10 2. dead-on-arrival (Win10) 3. works on Linux but we didn't want to try it again with Win10 After using it with my Win10 device (Lenovo, USB 3.0) two boards are now death. What could be the cause?
on Oct 08,2018
Reply upvote ()
Hi there, we use it on win10 pc and do not see the issue before. please drop a mail to techsupport@seeed.cc about the detail info. Can you see the respeaker in win10 device manager, please? how do you confirm them dead? thanks.
on Oct 09,2018 17:30 PM
Reply upvote ()
Reply upvote ()
Reply upvote ()
Reply
1
Is the processing that is shown on here only available if you are using the ReSpeaker's audio output jack? Or will this same processing work if music is played on an external speaker?
on Jun 05,2018
Reply upvote ()
yes, in the demo, we used an external speaker to plug into the 3.5mm jack. And it works well.
on Jun 05,2018 12:03 PM
Reply upvote ()
that is not what was asked.. they asked: if the music is being played say on a Sonos in the room (so not connected to the respeaker at all) will it be the same processing as shown in the demo above wave file samples? Or does the respeaker HAVE to be the device the music is being played through?? I am guessing as the 3.5mm Audio Jack is output only.. your answer is incorrect.. the array has to have the music being played through it, not externally to it to produce the above processed audio demo So the real question is how good is the mic array v2 at filtering out background music/talking and focusing on the voice in the DoA of the wake word ?
on Jun 14,2018 13:57 PM
Reply upvote ()
Hi,friend- you'd better contact us by email***techsupport@seeed.cc***, we can discuss more details about your problem, thanks!
on Jun 21,2018 13:07 PM
Reply upvote ()
Reply
0
Will you have accompanied enclosure? Or any 3rd party enclosures recommended?
on May 23,2018
Reply upvote ()
Hi there~ You can consider our ReSpeaker Pro Case. As long as you do not put the mic array 2.0 with respeaker core v1.0, the case can work with the ReSpeaker Mic Array v2.0. Regards. ======================================================================= https://www.seeedstudio.com/ReSpeaker-Pro-Case-p-2792.html
on May 24,2018 15:56 PM
Reply upvote ()
Thanks, but the product page says: >DISCONTINUED >This item is no longer available.
on May 24,2018 18:04 PM
Reply upvote ()
Hi, there. sorry, please search the key word for its more imformation, thanks!
on Jun 21,2018 16:46 PM
Reply upvote ()
Reply
0
What is the power consumption during listening?
on Jun 21,2018
Reply upvote ()
Hi, there- if you are using head set, power consumption is come from board. Regards!
on Jun 21,2018 17:08 PM
Reply upvote ()
That is clear what i would like to know the current that is drawn (example from USB power supply it sink 80mA). Im thinking to use it for battery powered device.
on Jun 21,2018 23:27 PM
Reply upvote ()
Reply
0
bonjour impossible de détecter le respeaker mic array v2.0 sur mon raspberry pi 3 besoin d'aide. merci
on Oct 27,2018
Reply upvote ()
Hi there, here are the items we can check. 1. please make sure the usb cable with 4 wires, vcc,gnd, dp, dm. it can transfer data. some usb cable has gnd and vcc only. 2. please connect to windows/mac to see if it can detect the mic array v2.0 3. please drop mail to techsupport@seeed.cc if the issue is not solved. thanks.
on Oct 29,2018 09:17 AM
Reply upvote ()
Reply
0
bonjour impossible de détecter le respeaker mic array v2.0 comme périphérique d'entré sur raspberry pi 3 besoin d'aide
on Oct 27,2018
Reply upvote ()
Reply upvote ()
Reply
0
Is this tested to work with Snips AI?
on Oct 12,2018
Reply upvote ()
Hi there, respeaker mic array v2.0 uses the usb1.0. You can connect it to raspberry pi to extract the audio. It shall support the snips ai. but we do not test it yet. thanks.
on Oct 15,2018 17:40 PM
Reply upvote ()
Reply
0
Does this work with Snips assistant?
on Oct 12,2018
Reply upvote ()
Hi there, it shall work, we can connect it to raspberry pi usb port. because the snips support the raspberry pi. thanks.
on Oct 12,2018 11:01 AM
Reply upvote ()
Reply
    View History
    SKU 107990053
    $69.00
    15 Available
    $69.00/ 1pcs+
    $62.10/ 10pcs+
    • Related
    • Description
    • Bundle sales
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
