seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      ReSpeaker Mic Array - Far-field w/ 7 PDM Microphones
      SKU 107010001
      $79.00
      20 Available
      $79.00/1pcs+
      $71.10/10pcs+
      $67.15/20pcs+
      $63.20/50pcs+
      ADD TO CART
      The ReSpeaker Mic Array can be stacked (connected) right onto the top of ReSpeaker Core to significantly improve the voice interaction experience. It is developed based on the XVSM-2000 Smart Microphone from XMOS. The board integrates 7 PDM microphones to help enhance ReSpeaker's acoustic DSP performance to a much higher level. With the Mic Array attached onto the top of the ReSpeaker Core, ReSpeaker is now able to:
      • Far-field Voice Capture
      • Acoustic Source Localization
      • Beamforming
      • Noise Suppression
      • De-reverberation
      • Acoustic Echo Cancellation
      • XMOS microcontroller with 16 cores inside
      • 7 high performance digital microphones
      • Supports Far-field Voice Capture (up to 10m)
      • Supports Beamforming, Acoustic Source Localization, Nosie Suppression, De-reverberation and Acoustic Echo Cancellation
      • 12 programmable RGB LED indicators
      • Microphones: ST MP34DT01-M
      • Sensitivity: -26 dBFS (Omnidirectional)
      • Acoustic overload point: 120 dBSPL
      • SNR: 61 dB
      • Power Supply: 5V DC from Micro USB or expansion header
      • Dimensions: 70mm (Diameter)
      • Weight: 15.25g
      Here is a video from Parvinder Yadav, it teaches how to use ReSpeaker Mic Array - Far-field w/ 7 PDM Microphones to make google assistant. We really appreciate Parvinder's contribution to the community and hope this video can be a good help for you.
      Technical Details
      Dimensions148mm x 100mm x 32mm
      WeightG.W 17g
      BatteryExclude
      ReSpeaker Far-filed Mic Array 1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hello, I want to use it with my android smartphone based 'OK Google' service, Can Re-speaker mic array interface directly to my android phone for far-field voice recognition?Are the other features of modules available at the same time ?How I can interface the module to my Android phone? USB or any other interface?Will it required any Drivers?
      on May 30,2017
      Replyupvote ()
      Update. Microphones are working on Windows 10. I have plugged them on Android using the OTG cable. I can hear the sound through the plug but the microphones do not transmit the sound. Is there any solution to this issue? Please advisehttps://ibb.co/jeAjtQ
      on Jun 22,2017 19:11 PM
      Replyupvote ()
      Reply
      1
      Where can i find the driver for respeaker Micarray UAC2.0? I can't install the mic array as microphone for my computer WIN7, please help!
      on Apr 20,2017
      Replyupvote ()
      Thanks, i have installed the driver, but i can't clearly distinguish the audio difference between your gadget with mine PC integrated mic, how so? should i adjust some parameter before using this?
      on Apr 24,2017 14:57 PM
      Replyupvote ()
      I want to use this mic array to connect with my android phone, is there any driver i should install in my phone?
      on Apr 24,2017 15:01 PM
      Replyupvote ()
      Reply
      1
      Can the ReSpeaker connect directly into windows via USB cable? Do you need special drivers?
      on Nov 23,2016
      Replyupvote ()
      How? It has invalid setup file on Windows. It can't be setup on Windows 8+. Really suck!!! No reply from these developers/founders/programmers. It should have a step by step how to setup on Linux /Windows...
      on Dec 15,2016 07:28 AM
      Replyupvote ()
      right click install ? its just an inf file that will make the device visible as a serial com I assume.
      on Feb 03,2017 02:06 AM
      Replyupvote ()
      Reply
      0
      I can install the driver but still can not connect the device.Please help!
      on Aug 29,2017
      Replyupvote ()
      Hi,there~ First, uninstall the driver, then disable digital signatures (please google how) , when you done ,install the driver again.Now it should be OK. Please contact us if you have any problem # techsupport@seeed.cc #
      on Oct 11,2017 11:24 AM
      Replyupvote ()
      Reply
      0
      How can I use ReSpeaker Mic Array on Windows 7 x64. When installing drivers, it says: "ERROR CODE (52)". I downloaded the driver from the github by reference.
      on Jun 12,2017
      Replyupvote ()
      Hi Andrew~ Please uninstall the driver, then disable digital signatures (please google how) , when you done ,install the driver again.Now it should be OK. Please contact us if you have any problem # techsupport@seeed.cc #
      on Oct 18,2017 11:40 AM
      Replyupvote ()
      Reply
      3
      The mic array must work with ReSpeaker Core or can it work individually as a microphone?
      on Nov 07,2016
      Replyupvote ()
      Thank you.
      on Nov 11,2016 09:19 AM
      Replyupvote ()
      Does that mean I could connect it via the usb interface to an raspberry pi directly, for example? I guess the necessary drivers are not (yet) released? Will there be drivers for the mic array alone?
      on Nov 29,2016 03:12 AM
      Replyupvote ()
      Reply
      0
      According to github page the firmware version 0x82 (raw) supports upto 32KHz 8 channel audio recording. I tried the 8 channel recording using Audacity (WASAPI) but the maximum sampling rate I could get was 8 KHz which was lower than that supported by earlier firmware. Further the node-HID tool does not seem to work with the new firmware.What can be done in this regard? How do I get higher sampling rate.
      on Jun 01,2017
      Replyupvote ()
      You can use pyaudio to 8 channel audio. On windows, you need the special pyaudio from http://www.lfd.uci.edu/~gohlke/pythonlibs/#pyaudio
      on Jun 01,2017 22:17 PM
      Replyupvote ()
      Thanks for the prompt reply, I was using this: https://stackoverflow.com/questions/26391055/multichannel-pyaudio-with-asio-support with pyaudio as you said but I am still getting only frequencies upto 4 KHz i.e. sampling rate of 8KHz. What can be done?
      on Jun 05,2017 17:43 PM
      Replyupvote ()
      Reply
      3
      Will the mic output the raw sound source position? What other comms are available to the board - I2C, SPI etc?
      on Nov 10,2016
      Replyupvote ()
      if you look at wiki https://github.com/respeaker/get_started_with_respeaker/wiki/Mic-Array at the protocol excel file, it has a voice angle 0-350 value. I assume I2C or Serial will be present (in addition to usb)
      on Feb 03,2017 02:04 AM
      Replyupvote ()
      What is the talker location ( Resolution) signal accuracy?
      on May 06,2017 09:47 AM
      Replyupvote ()
      Reply
      0
      Does Respeaker Mic Array work with Windows 10 IoT Core on the Raspberry Pi?
      on Nov 30,2017
      Replyupvote ()
      Hi there~ Unfortunately Windows 10 LoT for Raspberry Pi do not support Respeaker Mic Array.
      on Dec 01,2017 13:40 PM
      Replyupvote ()
      Reply
        View History
        SKU 107010001
        $79.00
        20 Available
        ADD TO CART
        $79.00/1pcs+
        $71.10/10pcs+
        $67.15/20pcs+
        $63.20/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
