Loading...
Rock Pi S PoE HAT
ROCK Pi S PoE HAT is a HAT accessory designed for ROCK Pi S. This HAT supports 802.3af Power Over Ethernet-enabled Networks with up to 10W(5V/2A) input. Also, there is an onboard EEPROM for HAT identity and driver probe. Furthermore, there is a headphone jack built-into the HAT and has a 2P connector that provides 12V power output. The HAT has an FPC connector to be used as a microphone extended interface.
$13.00
Out of stock
  • 802.3af up to 10W(5V/2A)
  • Optional 26-pin x2 GPIO pass-through included
  • Clean design which hides the transformer inside
  • EEPROM for HAT identity and driver probe
  • Headphone jack onboard
  • FPC connector for microphone extended interface
  • Provides 12V power output with 2P connector
ROCK Pi S PoE HAT is a HAT accessory designed for ROCK Pi S. The onboard Ethernet port on the Rock Pi S allows it to be used for IoT applications and you might come across situations where there is no power source with USB Type-C to power your Rock Pi S.
Rock Pi S PoE HAT comes in handy in those types of situations where it enables the Ethernet port to power your Rock Pi S as well. However, the connection should be a Power Over Ethernet-enabled Network where the network needs to have power-sourcing equipment installed.
  • 1 x ROCK Pi S PoE HAT
  • 4 x Mechanical spacers
HSCODE 8543709990
UPC
Documentations
Learn
If you want to learn more about the Rock Pi S PoE HAT, explore it's wiki here!
