seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      SMA M&M 6GHz Semi-Flexible cable RG402 - 10cm
      SKU 320160012
      $11.00
      9 Available
      $11.00/1pcs+
      $9.90/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This SMA male to male is a quality cable able to handle 6GHz with very low attenuation. It is the perfect cable to connect the RF Explorer Signal Generator to a device, or to work as a tracking generator.
      The semi-rigid nature of the cable allows for stable measurement independently of the position and helps on adding mechanical robustness when using RF Explorer Signal Generator with RF Explorer Spectrum Analyzer as Tracking Generator. You will typically need two of these cables to connect the Tracking Generator to a device (with two SMA female connectors) or use an equivalent Male to Female version for a device with different SMA gender connectors.
      • Very low VSWR and attenuation at high frequency
      • Robust semi-rigid mechanical strength
      • Wide broadband frequency application
      • Frequency range: DC - 6.0 GHz
      • Length: 10cm
      • Impedance (Nominal): 50Ω
      • Attenuation: 0.3dB max at 6GHz
      • Connector type: SMA male - female
      Technical Details
      Dimensions120mm x 80mm x 8mm
      WeightG.W 10g
      BatteryExclude
      SMA M&M 6GHz Semi-Flexible cable RG402 - 10cm1
      Documents
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 320160012
        $11.00
        9 Available
        Maximum Qty: 5
        $11.00/1pcs+
        $9.90/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
