SMA M&F 6GHz Semi-Flexible cable RG402 - 10cm
  • SMA M&F 6GHz Semi-Flexible cable RG402 - 10cm
SKU 320160013
This SMA male to female is a quality cable able to handle 6GHz with very low attenuation
Free Express Shipping on Orders over $200!
$11.00
1 Available
Qty:
This field is required
ADD TO CART
$10.18/10pcs+
$9.35/50pcs+
This SMA male to female is a quality cable able to handle 6GHz with very low attenuation. It is the perfect cable to connect the RF Explorer Signal Generator to a device, or to work as a tracking generator.
The semi-rigid nature of the cable allows for stable measurement independently of the position and helps on adding mechanical robustness when using RF Explorer Signal Generator with RF Explorer Spectrum Analyzer as Tracking Generator. You will typically need two of these cables to connect the Tracking Generator to a device (with two SMA male connectors) or use an equivalent Male to Male version for a device with different SMA gender connectors.
Features:
Very low VSWR and attenuation at high frequency
Robust semi-rigid mechanical strength
Wide broadband frequency application
Frequency range: DC - 6.0 GHz
Length: 10cm
Impedance (Nominal): 50Ω
Attenuation: 0.3dB max at 6GHz
Connector type: SMA male - female
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
See More
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Invalid email address.
