the AI Hardware Partner
Toggle Nav
Loading...
SMA Push-ON Male/Female adapter
Rating:
100 % of 100
The RF Explorer SMA Push-ON Male/Female adapter is great for repetitive connections to the SMA port
$9.78
Out of stock
The RF Explorer SMA Push-ON Male/Female adapter is great for repetitive connections to the SMA port. Normal threaded SMA ports are useful for permanent connection but this Push-ON adapter makes it very easy to plug-unplug a cable or device with just a slide gesture, no need to screw or thread the SMA connector.
Typically used for testing or momentary antenna measurements, these Push-ON adaptors are hard to find at this quality and price in low quantities.
The Push-ON adaptor is the same quality part included in the RF Explorer Near Field Antenna Kit. We benefit from our volume orders and therefore can pass this save cost to you.
  • Quality golden Push-ON connector on the Male side, normal threaded Female side.
  • Convenient for quick connections with a gesture
  • Easy to use for repetitive measurement
Dimensions 170mm x90mm x90mm
Weight G.W 4.5g
Battery Exclude
Impedance 50ohm
Connector Push-ON SMA Male, standard Female
Insulating Material Teflon
Contact material Gold (>3 micro inches)
Body material Brass/Beryllium Copper/Nickel
Bandwidth 6Ghz
VSWR <1.5
SMA Push-ON Male/Female adapter 1
HSCODE 9030900090
USHSCODE 8517180050
EUHSCODE 9030900000
COO TAIWAN
RoHS 1
  1. Product Quality
    100%
    By
1 Item
Show per page
