Seeeduino Cloud - Arduino Yun compatible openWRT controller
SKU 102010021
49.95
50+ Available
$49.95/ 1pcs+
$44.95/ 10pcs+
$42.46/ 20pcs+
$39.96/ 50pcs+
Seeeduino Cloud is a microcontroller board based on Dragino WiFi IoT module HE and ATmega32u4. HE is a high performance, low cost 150M, 2.4G WiFi module which means “core” in Chinese and with an Open Source OpenWrt system inside. Seeeduino Cloud is also an Arduino compatible board, 100% compatible with Grove, shield and IDEs(Arduino IDE 1.5.3 and later). Except for the normal interface of Arduino, Seeeduino Cloud has built-in Ethernet and WiFi support, a USB-A port which makes it very suitable for those prototype design that needs network connection and mass storage. It is also a good idea to make Seeeduino Cloud to an IoT gateway.
  • Compatible with Arduino Yun
  • Based on Dragino WiFi IoT module HE
  • Open Source OpenWrt system inside
  • Support 2.4Ghz WiFi, 802.11 b/g/n
  • Support Ethernet
  • Support USB 2.0
  • Size: 75.10mm x 53.39mm x 11.50mm / 2.95" x 2.10 x 0.45"
  • Working temperature: -20~60°C
  • Surface color: Red
Technical Details
Dimensions116mm x 76mm x 26mm
WeightG.W 53g
BatteryExclude
HE Module
CPU ATHEROS AR9331
Clock Speed 400MHz
RAM 64MB
Flash 16MB
OS Open Source OpenWrt
Interfaces 2 x RJ45, 1 x USB Host, 1 x UART, 14 multiplex GPIOs
Power 3.3V power input
WiFi Support 150M 2.4Ghz WiFi, 802.11 b/g/n
AVR Arduino Microcontroller
Microcontroller ATmega32u4
Flash Memory 32KB
SRAM 2.5kB
EEPROM 1kB
Clock Speed 16MHz
Digital I/O Pins 20
PWM Channels 7
Analog Input Channels 12
Seeeduino Cloud1
Antenna1
ECCN5A002.a.1
HSCODE8517709000
Reviews
Questions and Answers
SUBMIT
0
Has anyone used the USB2.0 slot for a thumb drive? That can be mapped (mounted) in OpenWrt on my YUN.
on Nov 14,2016
Reply upvote ()
Yes. As mentioned above you can use the USB 2.0 SanDisk Cruzer Low Profile thumb drive + the overlay-only script from the linino archive on github. This expands your OpenWrt partition across the thumb drive. Sketches and Linux have full access to everything. However if you do this your thumb drive becomes a permanent part of the board. You dont really need that USB port for anything else.
on Dec 24,2016 19:50 PM
Reply upvote ()
Reply
0
Hi., is there any sd card interface on Seeeduino Cloud?Thanks
on Oct 19,2016
Reply upvote ()
hi Jason, as you can see on the pictures it doesn't seem to have one on the board :-/ yet you get up to 64MB of Flash(NAND) spece (minus the OS FileSystem place of course ) for any datalogging feature if it's your intent. just be aware that NAN
on Oct 20,2016 10:50 AM
Reply upvote ()
I personally use the $6 SanDisk Cruzer Low Profile thumb drive and use the overlay-only script to extend the Linux OS and storage size to include the thumb drive size.
on Dec 24,2016 19:36 PM
Reply upvote ()
Reply
    View History
    SKU 102010021
    $49.95
    50+ Available
    $49.95/ 1pcs+
    $44.95/ 10pcs+
    $42.46/ 20pcs+
    $39.96/ 50pcs+
    • Related
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
