seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Seeeduino V4.2
      Seeeduino V4.2
      SKU 102010026
      $6.90$19.95
      50+ Available
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Seeeduino V4.2 is an Arduino-compatible board, which is based on ATmga328P MCU. There're so many Arduinos and Arduino-compatible boards in the world, and we think that Seeeduino V4.2 is one of the best Arduinos, Seeeduino V4.2 is much more stable, easy-to-use and even good looking.
      Seeeduino V4.2 is based the Arduino UNO bootloader, and with an ATMEGA16U2 as a Uart-to-USB converter, which means that the board can basically work like a FTDI chip. You can program the board via a micro-USB cable, if you have an Android phone, you can find a micro-ISB cable easily. Also you can power the board via a DC Jack input, 7 to 15V is acceptable. There's a switch to choose the system supply voltage, 3.3V or 5V, which is very useful if you want to set the system to 3.3V to save power.
      Finally, the three on-board Grove interface can make your board connect to Groves easily. Want to make something awesome, maybe just a Seeeduino V4.2 and some Groves is enough.
      • ATmega328P microcontroller
      • Arduino UNO bootloader
      • 14 Digital I/O Pins (6 PWM outputs)
      • 6 Analog Inputs
      • ISP Header
      • Arduino UNO-R3 Shield Compatible
      • Micro USB programming and power supply
      • 3 on-board Grove connectors
      • 3.3/5V system operation power switch
      Seeed Fusion has launched special offer for Duino customize service for over 1000 units. It is only $6900 in total for 1000 units Duino (you can design your own logo on Seeedunio). If you are interested in our special offer or have more questions regarding this service, please contact us at fusion@seeed.cc.
      Technical Details
      Dimensions115mm x 78mm x 25mm
      WeightG.W 41g
      BatteryExclude
      DC Current per I/O Pin40 mA
      DC Jack Input7v-12v
      Flash Memory32 KB
      RAM2 KB
      EEPROM1 KB
      Clock Speed16 MHz
      Seeeduino V4.21
      Reviews
      Questions and Answers
      SUBMIT
      0
      What is the polarity of the power supply? is it an inside positive?
      on Jul 29,2017
      Replyupvote ()
      Yes, you can see it at the back side of the board.Thanks.
      on Dec 02,2017 10:29 AM
      Replyupvote ()
      Reply
      0
      does it have two uarts (pin 0 and 1 ) and the groove header? or it is the same uart bus?
      on Jan 24,2018
      Replyupvote ()
      Hi there~ It is the same uart bus. Pin0-RX/D0 Pin1-TX/D1.Regards.
      on Jan 24,2018 09:23 AM
      Replyupvote ()
      Reply
      0
      I want to use DC power and the unit I would like to use is:https://www.adafruit.com/product/67What Seeed specification do I need to read to make sure this is compatible ?
      on Dec 18,2017
      Replyupvote ()
      Hi Julian~ You should choose 7-15V DC power.2000mA Max Regards
      on Dec 21,2017 18:18 PM
      Replyupvote ()
      Reply
      0
      I received replacement items that work fine out of the box. But where can I add to my Review?
      on Nov 01,2017
      Replyupvote ()
      Hi there~ Thanks for your understanding.We are glad it works fine with you now.Unfortunately, our system do not support Review modifying or adding. Again, we appreciate your kindness.Regards.
      on Dec 02,2017 10:40 AM
      Replyupvote ()
      Reply
      0
      delivery charges
      on Jul 28,2017
      Replyupvote ()
      Hi there~ You can see the delivery charges when you pay. Thanks
      on Dec 02,2017 10:27 AM
      Replyupvote ()
      Reply
        View History
        Seeeduino V4.2
        SKU 102010026
        $6.90$19.95
        50+ Available
        Maximum Qty: 5
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
