the AI Hardware Partner
Toggle Nav
Loading...
Serial-USB Module - .NET Gadgeteer Compatible
This product can now be purchased at www
$19.95
Out of stock
This product can now be purchased at www.ghielectronics.com.
Using this module, any of the serial UART sockets on mainboard can be converted into a virtual serial connection over USB. Use this connection to transfer data to a PC or for debugging over serial (virtual serial over USB). This is useful when needing to free up the USB client port for other purposes, like simulating a mouse or keyboard on USB Client port.
Works with any socket type U. Can also work with K sockets (serial + handshaking) with minor hardware changes. Note that K is purposely not marked on the module.
External Links
you need to download the following software to start your Gadgeteer:
  1. Development tool : Microsoft Visual C# Express 2010
  2. Micro framework: Microsoft .NET Micro Framework 4.1 SDK
  3. The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions 0mm x0mm x0mm
Weight G.W 8g
Battery Exclude
HSCODE
