Sick Of Beige Basic Case v1 50mm Square (DP5050)
SKU 110990089
3.00
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
A clear laser-cut acrylic project case kit that fits DP5050 square PCBs (50mmx50mm). Protect your project from electrical shorts and fingers, but keep it accessible for hacking and showing off. Sick of Beige basic case v1 is designed to be simple, cheap, and easy to assemble. The project PCB is sandwiched between two laser cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
Sick of Beige PCB templates and clear enclosures make it super easy to design your project for a case. Drop a standard PCB footprint on your schematic, and then route on the board template. The board shape, size, limitations, and many connector placements are already taken care of.
This case fits DP5050 (50mmx50mm PCB size) compatible PCBs.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Technical Details
Dimensions54mm x 54mm x 6.50mm
WeightG.W 29g
BatteryExclude
ECCNNot Available
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 110990089
    $3.00
    OUT OF STOCK
    $3.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
