the AI Hardware Partner
Toggle Nav
Loading...
Sick of Beige basic case v1 (DP6037)
Rating:
100 % of 100
A clear laser-cut acrylic project case kit
$3.00
Out of stock
  • 10+: $2.70
  • 20+: $2.55
  • More
  • 50+: $2.40
  • Less
A clear laser-cut acrylic project case kit. Protect your project from electrical shorts and fingers, but keep it accessible for hacking and showing off. Sick of Beige basic case v1 is designed to be simple, cheap, and easy to assemble. The project PCB is sandwiched between two laser cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
Sick of Beige PCB templates and clear enclosures make it super easy to design your project for a case. Drop a standard PCB footprint on your schematic, and then route on the board template. The board shape, size, limitations, and many connector placements are already taken care of.
This is a test batch of cases for DP6037 (60mmx37mm PCB size) compatible boards.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions 80mm x45mm x11mm
Weight G.W 26g
Battery Exclude
HSCODE 3926909090
UPC 841454103189
COO CHINA
  1. Product Quality
    100%
    By
  2. Product Quality
    100%
    By
2 Item(s)
Show per page
