seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Solar Charger Shield v2.2
      SKU 106990020
      $13.50
      12 Available
      $13.50/1pcs+
      $12.15/10pcs+
      $11.47/20pcs+
      $10.80/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      The solar charger is a stackable shield to Arduino compatible platforms, enables adaptive battery power and act as energy harvester for in-field charging. You may use various batteries that has the voltage of 3.0V-4.2V to shift up for 5V output, or put on Li-ion battery and solar panel to form an autonomous sensor unit. The maximum current provided by the board can get up to 600mA. An usb connector is also useful to charge the battery.
      Features:
      • Output Disconnect
      • Short circuit protection
      • 3W Output Power when connecting battery
      • Continuous Charge Current Up to 900mA
      • Battery status indication ( Red : Charging , Green: Charged )
      • Micro-USB Connector
      Specification:
      • Battery input voltage: 3.0~4.5V
      • USB input voltage: 4.75~5.25V
      • Solar input voltage: 4.8~6V
      • Maximum Output Power(with battery): 3W(600mA@5V)
      • Ripple voltage:<100mV @ 500mA
      • Dimensions: 68*53mm
      Technical Details
      Dimensions115mm x 75mm x 25mm
      WeightG.W 42.5g
      BatteryExclude
      Solar Charger Shield v2.21
      Reviews
      Questions and Answers
      SUBMIT
      1
      What versions of Arduino will this stack onto? Is the shield compatible with both R2 and R3 footprints? https://learn.sparkfun.com/tutorials/arduino-shields#installing-headers-preparation
      on Apr 26,2017
      Replyupvote ()
      why that solar module does not supply Arduino. but battery is charged.
      on Apr 30,2017 23:20 PM
      Replyupvote ()
      it is arduino yun
      on Apr 30,2017 23:24 PM
      Replyupvote ()
      Yes, works with both R2 and R3.
      on Jan 09,2018 11:18 AM
      Replyupvote ()
      Reply
      0
      - What is the power consumption (in mA) of the solar shield board when there is no solar panel connected and using the shield to supply power to Arduino by 3.7V battery? We measured about 40mA current.- We are using solar panel to charge the LiPo battery. After a few days, the battery ran out of power. Would your Solar Charger Shield wake the Arduino up when there is sun (sunny day)?
      on Jun 07,2017
      Replyupvote ()
      You can acquire this from our wiki : http://wiki.seeed.cc/Solar_Charger_Shield_V2.2/
      on Jan 09,2018 11:39 AM
      Replyupvote ()
      Replyupvote ()
      Reply
      0
      What solar panel and battery would you recommend for this? wiki page says to not run the shield at higher than 5V but the lowest voltage panel I can find is a .5W one that could output as high as 10V: https://www.seeedstudio.com/0.5W-Solar-Panel-55x70-p-632.html
      on May 12,2017
      Replyupvote ()
      Hello, as for the battery, any 3.7V lipo battery is fine, but we don't have battery here.The panel you had memtioned is ok.Thanks.
      on Jan 09,2018 11:19 AM
      Replyupvote ()
      Reply
      0
      what happen1. if LiPo battery connected opposite? (+/-)2. if solar pannel voltage is lower than 4.8V3. Finally, why whole kit get hotter when LiPo battery connected?(untouchable)
      on Jul 30,2017
      Replyupvote ()
      1.The solar charger shield is designed to protect any potential short circuit. However care must be taken to avoid any such situations.2.It's OKEY,but it is recommended to use solar pannel with solar input voltage:4.8~6V3.Electric heat,take is easy
      on Jan 09,2018 11:31 AM
      Replyupvote ()
      Reply
      0
      Is it possible to control the on board leds in order to save energy?
      on Jun 23,2018
      Replyupvote ()
        View History
        SKU 106990020
        $13.50
        12 Available
        Maximum Qty: 5
        $13.50/1pcs+
        $12.15/10pcs+
        $11.47/20pcs+
        $10.80/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
