The AirBoard - prototyping platform For IoT
This product contains battery, might applys to shipping constriction.
SKU 114990395
30.00
19 Available
$30.00/ 1pcs+
$29.50/ 10pcs+
The AirBoard is a wireless, modular and ultra low-power prototyping platform for the Internet of Things, designed to explore, hack and deploy your killer idea out in the field.
Note
The AirBoard comes with a built-in battery.
The AirBoard has been designed to be wirelessly reprogrammable. The microUSB connector is used for battery charging only. To upload a new program, you will need additional wireless shields such as XBee or BLE and their associated USB dongle, or an external serial connection over FTDI.
  • Go wireless
  • Explore the hotest wireless technologies today: with its popular Bee form factor, the AirBoard features a socket for XBee, Bluetooth, BLE and WiFi wireless shields, as well as the recent GSM/GPRS, SIGFOX and LoRa WAN long range IoT modules. Simply swap the radio for instant communication and WPAN Over-The-Air Programming.
  • Iterate quickly
  • The AirBoard was designed with productivity in mind. Design and iterate quickly with the built-in open solderless breadboard. Only Arduino’s most popular I/Os are exposed, in order to lower the cognitive barrier and encourage the highest experiment turnover. Snap in hundreds of sensors and experiment a whole library of interactions in just seconds.
  • Deploy your device in the field
  • Beyond the Internet of Things, ubiquitous devices require efficient Power and Data Management strategies to become truly autonomous.
  • Ultra Power Efficient
  • Forget about your sensors with the built-in battery and Power Management System. The AirBoard is designed for ultra low-power applications, yet capable to drive long range wireless shields. It offers an ultra-low power sleep mode with switchable radio for most efficient communication strategy.
  • Your first sketch in seconds
  • Start programming straight from the box with this superb web IDE by codebender. All required libraries and quick start source codes have been installed already. And with the pre-loaded Arduino Fio bootloader, you can also use the Arduino IDE. So why don’t you wait and start sketching now!
  • Make your own App
  • It’s no longer needed to be an expert in programming to build pretty AND functional Graphical User Interfaces. Have fun interacting with your tangible hardware right away! Just drag and drop a whole library of widgets to build your own mobile app. remotexy and Blynk work seamlessly with the AirBoard and are great examples of bringing rapid prototyping to everyone.
Size and Weight
  • 41x25x9mm
  • Weight, including battery: 10g
Native Arduino Processor
  • Arduino compatible
  • ATmega328P processor @ 8MHz
  • Pre-loaded Arduino Fio bootloader
  • Arduino IDE support
  • Codebender web IDE support
Open solderless breadboard and socket headers
  • 7x GPIO, I2C, SPI, 2x 10-bit ADC, 3x PWM
  • 5VUSB/500mA, 3.3V/200mA power outputs
  • Up to 18x GPIOs, 6x 10-bit analog inputs or 6x PWMs
Bright RGB LED
  • RGB LED, up to 2240mcd, 120° viewing angle
Wireless
  • « Bee » socket form factor
  • Wireless support: XBee, Bluetooth 2.1,  Bluetooth Low Energy 4.0, WiFi,GSM/GPRS, SIGFOX, LoRa WAN
  • 2-channel Over-The-Air Programming (OTAP)
  • 5-second programming via XBee, Bluetooth, WiFi
Ultra Low Power Management System
  • 155mAh rechargeable lithium-ion battery
  • 1A switchable RF LDO
  • 330nA system deep sleep
  • Autonomy in sleep mode: 2-3 years
  • Autonomy in communication: 6 months (XBee 1 data/minute)
Built-in battery charger
  • 1-cell Li-ion USB charger
  • Battery Over Current, Charge & Discharge protect
  • Battery level indicator, charge status, USB voltage monitor
  • Charge time: 1.5 hours
  • 1x airboard
  • 1x Lipo battery
Documents
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 12g
BatteryLithium Cells / Batteries contained in equipment UN3481 - PI967
ECCNNot Available
HSCODE8517709000
Certification
RoHSCompliant
CertificationCE
Reviews
Questions and Answers
SUBMIT
0
Hi, does the basic AirBoard provides Wifi wireless connection or we have to by in additional the shield. Best regards, Walter
on Apr 15,2017
Reply upvote ()
This is the Basic AirBoard with built-in battery. You can use the ESP8266 Wifi Bee (www.dfrobot.com/product-1279.html), but you also need a BLE_LINK/USB dongle or XBee/Explorer dongle combo for programming (see references, tuto and faq on www.theairboard.cc).
on Sep 08,2017 13:06 PM
Reply upvote ()
Reply
0
Hello, Does the airboard is provided with the BLE shield from DRobot and the usb dongle for programming? Thanks for your answers.Alexis
on Oct 19,2016
Reply upvote ()
please refer to http://www.seeedstudio.com/wik..., for the detailed information about the LED indicators.
on Oct 20,2016 10:47 AM
Reply upvote ()
This is the Basic AirBoard only with built-in battery. You can get BLE shield (requires hack) and dongle directly from DFRobot.
on Dec 04,2016 17:32 PM
Reply upvote ()
Reply
    View History
    SKU 114990395
    $30.00
    19 Available
    $30.00/ 1pcs+
    $29.50/ 10pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
