seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      UDOO NEO FULL
      UDOO NEO FULL
      SKU 102110079
      $64.90
      DISCONTINUED
      UDOO NEO is whatever you need to approach the world of makers.
      Launched in 2015 and funded by thousands of enthusiasts worldwide through Kickstarter, UDOO NEO is an Arduino-powered Android / Linux single board computer enriched with 9-axis motion sensors, Bluetooth 4.0 and a Wi-Fi module.
      The unique feature of UDOO NEO is its heterogeneous processor, based on two cores embedded on the very same chip. We are speaking of a powerful 1GHz ARM® Cortex-A9and an Arduino UNO-compatible platform that clocks at 200 MHz, based on a Cortex-M4 I/O real-time co-processor, all wrapped into an i.MX 6SoloX processor by NXP.
      UDOO NEO can be used in many ways. First of all as a low power computer attached to a screen, a mouse and a keyboard. In a second place it can be used as a ARM development board as well as a ATMEL development board. This is the context where the board shines the most, ensuring compatibility  You can make the most out of it if you build a drone, a robot, a rover, a 3D printer, a home automation service, an autonomous system. Finally, it can be exploited as an embedded board, i.e. a board designed to work within an embedded context.
      The most complete tool for wireless mobile IoT applications.
      UDOO NEO FULL is the best, all-in-one solution for wireless mobile IoT applications.
      UDOO NEO FULL can be powered in three ways. You can use:
      • A standard 12 volts power supply.
      • A Micro USB cable like this one.
      • Any USB battery pack available on the market.
      You can use it as a Headless Device, exploiting the USB and Ethernet ports and the Wireless Connectivity - a powerful Wi-Fi b/g/n and the newest Bluetooth 4.0. You can also use it as a computer, thanks to its 1GB of RAM. The board is compatible with most Arduino shields, sensors and actuators. UDOO NEO FULL is also compatible with UDOO Bricks: programmable modules, like the temperature sensor and the barometric sensor, that you can add to make UDOO NEO FULL even more versatile.
      • Freescale™ i.MX 6SoloX applications processor with an embedded ARM Cortex-A9 core and a Cortex-M4 Core
      • Integrated 2d/3d graphics controller
      • RAM 1GB
      • Micro HDMI interface - LVDS interface + touch (I2C signals)
      • Analog camera connection supporting NTSC and PAL - 8-bit parallel camera interface
      • MicroSD card slot onboard - 8-bit SDIO interface
      • HDMI audio transmitter - S/PIDF & I2S
      • 1x USB 2.0 Type A ports - 1x USB OTG (micro-AB connector)
      • Fast ethernet RJ45 – 10/100Mbps - Wi-Fi 802.11 b/g/n,Direct Mode SmartConfig and Bluetooth 4.0 Low Energy
      • 3x UART ports - 2x CAN Bus interfaces
      • 8x PWM signals - 3x I2C interface - 1x SPI interface - 6x multiplexable signals
      • Power Supply: 5 V DC Micro USB, 6-15 V DC Power Jack, RTC Battery Connector
      • Green Power Status LED - User Configurable LEDs (Red and Orange)
      • Integrated Sensors: 3-Axis Accelerometer - 3-Axis Magnetometer - 3-Axis Digital Gyroscope - 1x Sensor Snap-In I2C connector
      • Dimensions: 89mm x59mm (3.50″ x 2.32″)
      • Arduino-Compatible through the standard Arduino Pins layout and compatible with Arduino shields
      • 32 extended GPIOs (A9 dedicated) - 22 arduino GPIOs (M4 dedicated)
      • 6 available Pins
      • Android Lollipop & Linux UDOObuntu2 (14.04 LTS)
      For more information, please click UDOO Neo Docs
      Technical Details
      Dimensions100mm x 70mm x 25mm
      WeightG.W 60g
      BatteryExclude
      UDOO NEO FULL 1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        UDOO NEO FULL
        SKU 102110079
        $64.90
        DISCONTINUED
        $64.90/1pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
