Uart Camera Module with Jpeg compression - C328
  • Uart Camera Module with Jpeg compression - C328
SKU SEN121A2M
This item is no longer for sale
Free Express Shipping on Orders over $200!
$49.90
DISCONTINUED
This item is no longer for sale.
The C328 module is a highly integrated serial camera board that can be attached to a wireless or PDA host performing as a video camera or a JPEG compressed still camera. It provides a  serial interface and JPEG compression engine to act as a low  cost and low  powered camera module for high-resolution serial bus security system or PDA accessory applications.
● Small in size,  low cost and low  powered  (3.3V) camera module for  high-resolution serial bus security system or PDA accessory applications.
● On-board EEPROM provides a command-based interface to external host via RS-232.
●  UART: 115.2Kbps for transferring JPEG still pictures or 160x128 preview @8bpp with 0.75fps.
●  On board OmniVision  VGA color sensor.
●  Built-in JPEG CODEC for different resolutions.
●  Built-in down sampling, clamping and windowing circuits for VGA, QVGA, 160x120 or 80x60 image resolutions.
●  Built-in color conversion circuits for 2-bit gray, 4-bir gray, 8-bit gray, 12-bit RGB, 16-bit RGB or standard JPEG preview images.
●  No external DRAM required.
System Configuration
1. Camera Sensor
The C328 module uses OmniVision  VGA color digital CameraChips with an 8-bit YCbCr interface.
2. OV528 Serial Bridge
The OV528 Serial Bridge is a JPEG CODEC embedded controller chip that can compress and transfer image data from CameraChips to  external device. The OV528 takes 8-bit YCbCr 422 progressive video data from an Sensor CameraChip. The camera interface synchronizes with input video data and performs down sampling, clamping and windowing functions with desired resolution, as  well as color  conversion that is  requested by the  user through serial  bus  host
commands.
The JPEG CODEC can achieve higher compression ratio and better image quality for  various
image resolutions.
3. Program EEPROM
A serial type program  memory is built-in  for  C328 to provide a set of user-friendly command interfacing to external host.
Documents
Please visit our wiki page for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
See More
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Free shipping off on your first order over $50 or more. Discounted items included!
Invalid email address.
