the AI Hardware Partner
Toggle Nav
Loading...
WiFi Serial Transceiver Module w& ESP8266
Please consider WiFi Serial Transceiver Module w/ ESP8266 as alternative productThis version of WiFi Serial Transceiver Module is discontinued, please consider the latest version: WiFi Serial Transceiver Module w& ESP8266 – 1M Flash
$6.95
Out of stock
This version of WiFi Serial Transceiver Module is discontinued, please consider the latest version: WiFi Serial Transceiver Module w& ESP8266 – 1M Flash. There is not much change from the old version, just improved the Flash to be 1M and changed the color to be black, which is much cooler than blue.
We release a tutorial for ESP8266.
This is WiFi serial transceiver module, based on ESP8266 SoC.
The SOC has Integrated TCP/IP protocol stack
We have a set of documents in Chinese. We are preparing tutorials and demo software to showcase utility of this module.
Please buy this module only when you understand the existing documents.
ESP8266 is a highly integrated chip designed for the needs of a new connected world. It offers a complete and self-contained Wi-Fi networking solution, allowing it to either host the application or to offload all Wi-Fi networking functions from another application processor.
ESP8266 has powerful on-board processing and storage capabilities that allow it to be integrated with the sensors and other application specific devices through its GPIOs with minimal development up-front and minimal loading during runtime. Its high degree of on-chip integration allows for minimal external circuitry, and the entire solution, including front-end module, is designed to occupy minimal PCB area.
Corresponding Interface:
SDIO 2.0, SPI, UART
32-pin QFN package
Integrated RF switch, balun, 24dBm PA, DCXO, and PMU
Integrated RISC processor, on-chip memory and external memory interfaces
Integrated MAC/baseband processors
Quality of Service management
I2S interface for high fidelity audio applications
On-chip low-dropout linear regulators for all internal supplies
Proprietary spurious-free clock generation architecture
Integrated WEP, TKIP, AES, and WAPI engines
Specification:
802.11 b/g/n
Wi-Fi Direct (P2P), soft-AP
Integrated TR switch, balun, LNA, power amplifier and matching network
Integrated PLLs, regulators, DCXO and power management units
+19.5dBm output power in 802.11b mode
Power down leakage current of<10uA
Integrated low power 32-bit CPU could be used as application processor
SDIO 1.1/2.0, SPI, UART
STBC, 1&times;1 MIMO, 2&times;1 MIMO
A-MPDU & A-MSDU aggregation & 0.4ms guard interval
Wake up and transmit packets in < 2ms
Standby power consumption of < 1.0mW (DTIM3)
Resource
Espressif AT Instruction Set(Chinese)
ESP8266 Specifications(Chinese)
ESP8266 Datasheet ( Thanks Zarya for translate )
ESP8266 Community Forum
Software:
ESP8266 IoT SDK
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 3g
Battery Exclude
WiFi Serial Transceiver Module w& ESP8266 1
HSCODE 8517709000
  1. Product Quality
    100%
    By
  2. Product Quality
    40%
    Insufficient radio characteristics, unfortunately. Not recommended for industrial solutions.
    By
2 Item(s)
Show per page
