seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Wifi Shield V2.0
      Wifi Shield V2.0
      SKU 113030008
      $39.95
      OUT OF STOCK
      This item is not available at the moment
      Get notified when it's back in stock
      Featured with RN171 TCP/IP module, the WiFi shield allows your Arduino/Seeeduino to connect wireless networks up to 802.11b/g. The RN171 module supports TCP, UDP, FTP and HTTP communication protocols, which meet the needs of most wireless and Internet of Things (IoT) network projects, such as smart home networks, robots controls and personal weather stations.
      The shield covers a wide range and transmit strong signals with the newly, stable on-board antenna. The default communication protocol with the Arduino is UART/Serial, and you can select which digital pins (D0 to D7) to use for RX and TX with the two jumper rows we've incorporated. The shield also has two Grove connectors of I2C and Serial to make it can be plugged with any other Groves.
      The shield is well documented with demos and you can check the User Manual here online.
      • Various demos with step-by-step tutorials
      • Low power consumption
      • Compatible with Arduino, easy to get started with
      • CMD Support
      Technical Details
      Dimensions100mm x 65mm x 30mm
      WeightG.W 41g
      BatteryExclude
      Voltage3.3~5.5 V
      Current25~400mA
      Transmit power0-10 dBm
      Frequency2402~2480 MHz
      InterfaceUART (Software serial, you can choose the digital pins as RX and TX of RN171)
      Network rate1-11 Mbps for 802.11b/6-54Mbps for 802.11g
      Secure WiFi authenticationWEP-128, WPA-PSK (TKIP), WPA2-PSK (AES)
      Built-in networking applicationsDHCP client, DNS client, ARP, ICMP ping, FTP, TELNET, HTTP, UDP, TCP
      RN-171WIFLY GSX 802.11 b/g Wireless LAN Module.
      Wifi Shield V2.01
      Documents
      Reviews
      Questions and Answers
      SUBMIT
      0
      Anyone have any luck with a MQTT protocol within the Arduino IDE?
      on Apr 26,2018
      Replyupvote ()
        View History
        Wifi Shield V2.0
        SKU 113030008
        $39.95
        OUT OF STOCK
        $39.95/1pcs+
        $37.95/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
