Loading...
Smart Garden IoT Monitor built with Wio Terminal
With the Wio Terminal Smart Garden Kit, you can collect and measure soil moisture, light, temperature, and humidity for plants on the Wio Terminal LCD and visualize data! Conveniently use a suite of plug-and-play Grove sensor modules, and display the information neatly on the Wio Terminal's built-in display. With onboard Bluetooth or WiFi, you can even add cloud capabilities to your smart garden system and view the collected data remotely!
$3.30
    Feature
    • Create a sustainable growth environment for your plant
    • Collect, measure, and visualize light, humidity, temperature, and soil on the screen
    • Cloud and remotely collecting data are supported via WiFi and Bluetooth
    Interested in home gardening? At the first glance, growing your own plants can appear deceptively easy. In reality, it's difficult to properly manage the variety of factors that affect plant growth - such as light, humidity, temperature, and soil moisture. Monitoring is quite essential for greenhouses because changes in the growing environment can be dealt with before they damage plants.
    With the Wio Terminal Smart Garden Kit, the days of dead plants and heartbreak are long gone. You can collect and measure soil moisture, light, temperature, and humidity for plants on the Wio Terminal LCD and visualize data! Conveniently use a suite of plug-and-play Grove sensor modules, and display the information neatly on the Wio Terminal's built-in display. With on-board Bluetooth or WiFi, you can even add cloud capabilities to your smart garden system and view the collected data remotely!
    Now, you can care for your plants properly and conveniently by giving them exactly what they need!
    The soil moisture sensor consists of two probes that allow the current to pass through the soil and then obtain resistance values to measure soil moisture content. DHT11 Sensor provides a wider range of temperature and humidity measurements and higher temperatures.
    Application
    • Smart Plant Care
    • Smart Garden
    Resource
    Wio Terminal Classroom #12 | Smart Garden Project using Wio Terminal
    Resource Roundup for Wio Terminal: Tutorials, Reviews, and Projects from Community
    Documentations
    Learn
