the AI Hardware Partner
Toggle Nav
Loading...
Xbee ZigBee SMT 250kbps 1200m RF Module w& U.Fl Antenna Connector - XB24CZ7UIS-004
Rating:
100 % of 100
XBee ZB embedded SMT RF modules, xbee, xbee zb,Xbee ZigBee SMT 250kbps 1200m RF Module w& U.Fl Antenna Connector - XB24CZ7UIS-004
$39.95
Out of stock
  • 10+: $35.96
XBee ZB embedded SMT RF modules provide cost-effective wireless connectivity to end-point devices in ZigBee mesh networks. They require no configuration or additional development; users can have their network up and running in a matter of minutes.
Programmable versions of the SMT module make customizing ZigBee application easy, even without wireless design expertise. Features like binding and multicasting also allow for simple integration into a Home Automation device.
FEATURES
  • Interoperability with ZigBee devices from other vendors
  • Firmware upgrades via UART, SPI or over the air
  • Supports binding and multicasting, for easy integration into a Home Automation platform
  • SMT form factor with side Castellations for easy soldering
  • Programmable ZigBee SMT available
SPECIFICATION
  • Data Rate: RF 250 Kbps, Serial up to 1 Mbps
  • Indoor/Urban Range: 200 ft (60 m)
  • Outdoor/RF Line-of-Sight Range: 4000 ft (1200 m)
  • Transmit Power: 3.1 mW (+5 dBm) / 6.3 mW (+8 dBm) boost mode
  • Receiver Sensitivity: (1% PER) -100 dBm / -102 dBm boost mode
  • Serial Data Interface: UART, SPI
  • Configuration Method: API or AT commands, local or over-the-air
  • Frequency Band: ISM 2.4 GHz
  • Interference Immunity: DSSS (Direct Sequence Spread Spectrum)
  • ADC Inputs: (4) 10-bit ADC inputs
  • Digital I/O: 15
  • Antenna Options: PCB (embeded), U.FL and RF PAD
  • Operating Temperature: -40°C to +85°C
  • Dimensions (L x W) and Weight: 0.87 in x 1.33 in x 0.12 in (2.20 cm x 3.40 cm x 0.30 cm); 1.40 oz (40.00g)
  • Memory: N/A
  • CPU/Clock Speed: N/A
NETWORKING AND SECURITY
  • Protocol: ZigBee PRO 2007, HA-Ready with support for binding/multicasting
  • Encryption: 128-bit AES
  • Reliable Packet Delivery: Retries/Acknowledgments
  • IDs: PAN ID and addresses, cluster IDs and endpoints (optional)
  • Channels: 16 channels
POWER REQUIREMENT
  • Supply Voltage: 2.1 to 3.6V
  • Transmit Current: 33 mA @ 3.3 VDC /45 mA boost
  • Receive Current: 28 mA @ 3.3 VDC /31 mA boost mode
  • Power-Down Current: < 1 uA @ 25°C
Dimensions 50mm x70mm x3.4mm
Weight G.W 4g
Battery Exclude
XBee ZB embedded SMT RF modules 1
HSCODE 8517709000
UPC 841454101048
  1. Product Quality
    100%
    By
  2. Product Quality
    100%
    By
2 Item(s)
Show per page
