seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Xbee ZigBee SMT 250kbps 1200m RF Module w& U.Fl Antenna Connector - XB24CZ7UIS-004
      SKU 113990074
      $7.50$39.95
      11 Available
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      XBee ZB embedded SMT RF modules provide cost-effective wireless connectivity to end-point devices in ZigBee mesh networks. They require no configuration or additional development; users can have their network up and running in a matter of minutes.
      Programmable versions of the SMT module make customizing ZigBee application easy, even without wireless design expertise. Features like binding and multicasting also allow for simple integration into a Home Automation device.
      FEATURES
      •     • Interoperability with ZigBee devices from other vendors
      •     • Firmware upgrades via UART, SPI or over the air
      •     • Supports binding and multicasting, for easy integration into a Home Automation platform
      •     • SMT form factor with side Castellations for easy soldering
      •     • Programmable ZigBee SMT available
      SPECIFICATION
      •     • Data Rate: RF 250 Kbps, Serial up to 1 Mbps
      •     • Indoor/Urban Range: 200 ft (60 m)
      •     • Outdoor/RF Line-of-Sight Range: 4000 ft (1200 m)
      •     • Transmit Power: 3.1 mW (+5 dBm) / 6.3 mW (+8 dBm) boost mode
      •     • Receiver Sensitivity: (1% PER) -100 dBm / -102 dBm boost mode
      •     • Serial Data Interface: UART, SPI
      •     • Configuration Method: API or AT commands, local or over-the-air
      •     • Frequency Band: ISM 2.4 GHz
      •     • Interference Immunity: DSSS (Direct Sequence Spread Spectrum)
      •     • ADC Inputs: (4) 10-bit ADC inputs
      •     • Digital I/O: 15
      •     • Antenna Options: PCB (embeded), U.FL and RF PAD
      •     • Operating Temperature: -40°C to +85°C
      •     • Dimensions (L x W) and Weight: 0.87 in x 1.33 in x 0.12 in (2.20 cm x 3.40 cm x 0.30 cm); 1.40 oz (40.00g)
      •     • Memory: N/A
      •     • CPU/Clock Speed: N/A
      NETWORKING AND SECURITY
      •     • Protocol: ZigBee PRO 2007, HA-Ready with support for binding/multicasting
      •     • Encryption: 128-bit AES
      •     • Reliable Packet Delivery: Retries/Acknowledgments
      •     • IDs: PAN ID and addresses, cluster IDs and endpoints (optional)
      •     • Channels: 16 channels
      POWER REQUIREMENT
      •     • Supply Voltage: 2.1 to 3.6V
      •     • Transmit Current: 33 mA @ 3.3 VDC /45 mA boost
      •     • Receive Current: 28 mA @ 3.3 VDC /31 mA boost mode
      •     • Power-Down Current: < 1 uA @ 25°C
      Technical Details
      Dimensions50mm x 70mm x 3.4mm
      WeightG.W 4g
      BatteryExclude
      XBee ZB embedded SMT RF modules1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 113990074
        $7.50$39.95
        11 Available
        Maximum Qty: 5
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
