Grove - I2C ADC
Rating:
100% of 100
Provides up to 9 I2C ADC at the sametime Support automatic power-down mode Changeable I2C address Low power consumption Grove connector compatible
$12.90
In stock
  • 10+: $11.61
  • 20+: $10.97
  • More
  • 50+: $10.32
  • Less
Grove - I2C ADC is a 12-bit precision ADC module based on ADC121C021. It helps you increase the accuracy of value collected from analog sensor by providing a constant reference voltage. Because its address is changeable, you can use up to 9 I2C ADC at the same time at most. At the other hand, this module provides auto sleep function which lowers the power consumption considerably.
  • Low power consumption
  • High precision
  • Automatic power-down mode
  • Address changeable
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Dimensions 60mm x90mm x10.6mm
Weight G.W 10g
Battery Exclude
Grove - I2C ADC 1
Grove Cable 1
ECCN 3A991.c
HSCODE 8517709000
USHSCODE 8517700000
UPC 841454108238
ROHS 1
BeagleBone Green Temperature Monitor on Artik Cloud
Publish Grove Temperature Sensor values collected by a BeagleBone Green to Artik Cloud.
DIY a Retro Wooden Lamp with BBG
You can built so many beautiful things with wooden and laser cutter. And it will much more better if add some electric modules, we call it the combination of electronic and art. Here I will share my latest creation, a wooden lamp that the color control
Grove - I2C ADC
Wiki of Grove - I2C ADC
Customer Reviews
  1.
    Rating
    100%
    OK
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
