This product is retired, please consider the new version Grove - Mini Fan V1.1.
Grove - Mini Fan is a DC motor driver base on AVR microcontroller Atmega168,you can change code by breakout , this module also reserve servo connector,it can driver servo by change code ,Grove - Mini Fan is design for kids, which is use soft fan-leafed in order to avoid unnecessary damage.
  • Grove connector
  • Soft fan-leafed
  • Arduino compatible
  • User-friendly
  • Grove - Mini Fan
  • Fan
  • DC Motor
  • Grove Cable-20cm
Dimensions 110mm x70mm x26mm
Weight G.W 32g
Battery Exclude
Grove - Mini Fan 1
Grove - Mini Fan
The Grove - Mini Fan module is a DC motor driver based on the AVR Atmega168 microcontroller. The module also provides a breakout through which you can change the microcontroller code.
Product Faqs
Sort by
