Mbed LPC1114FN28 - ARM Cortex-M0
mbed LPC1114FN28 enables you to use NXP LPC1114FN28 (ARM Cortex-M0 MCU in DIP28 package) on the mbed development environment easily
- 10+: $22.41
- 20+: $21.17
mbed LPC1114FN28 enables you to use NXP LPC1114FN28 (ARM Cortex-M0 MCU in DIP28 package) on the mbed development environment easily. It is bundled with an LPC1114FN28.
The LPC1114FN28 is an ARM Cortex-M0 based, mbed enabled microcontroller, offering performance, low power, simple instruction set and memory addressing together with reduced code size compared to existing 8/16-bit architectures.
It is made particularly unique by the fact that it is available in a 28-pin dual-in-line package, making it perfect for breadboarding, and/or replacing 8 bit micro-controllers that you may have used just because they are available in a DIP package. You can develop a software by mbed, LPCXpresso, MDK-ARM, etc.
No program is written on the LPC1114FN28. Because an I/F chip on the substrate backside has a function of writing, you can use it as a writer of LPC1114FN28 with the ZIF socket. The Micro-B USB receptacle comes with mbed LPC1114FN28.
You can use it in the same way as other mbed through a Micro-B USB cable.
Documents:
Dimensions | 70mm x50mm x23mm |
Weight | G.W 12g |
Show
per page
