the AI Hardware Partner
Toggle Nav
Loading...
Circuit Sticker Effects Kit - twinkle&heartbeat&fade&blink
Rating:
100 % of 100
Circuit Stickers are electronic stickers that you can use to build glowing, sensing, and interactive projects without any complicated equipment or programming skills
$14.90
Out of stock
  • 10+: $13.41
  • 20+: $12.67
Circuit Stickers are electronic stickers that you can use to build glowing, sensing, and interactive projects without any complicated equipment or programming skills. All you need is your imagination.
And this is an add-on effects kit for Circuit Sticker Starter kit, which makes your LEDs fade, blink, twinkle or pulse a heartbeat rhythm. There are 1pcs for each effect.
Building circuits with them is fun and easy -- just stick them onto a surface like you would with a normal sticker, and build up a circuit by sticking several stickers together and adding a battery. They’re an approachable way to learn and create electronics through craft, whether you’re just starting out with circuits or creating complex interactive artworks.
Documents
Have more creative ideas on circuit stickers? Need any help when using circuit stickers? You are welcomed to write your words on the chibitronics forum.
Dimensions 110mm x100mm x5mm
Weight G.W 6g
Battery Exclude
HSCODE 9023009000
ROHS 1
  1. Product Quality
    100%
    By
1 Item
Show per page
