the AI Hardware Partner
Toggle Nav
Loading...
RePhone core 2G-AtmelSAMD21
Rating:
100 % of 100
RePhone is one of the most unique and interesting development board platform that created by Seeed Studio, with RePhone you can not only DIY a special phone for yourself, but also enchant things around you with cellular connectivity
$36.04
Out of stock
  • 10+: $32.44
RePhone is one of the most unique and interesting development board platform that created by Seeed Studio, with RePhone you can not only DIY a special phone for yourself, but also enchant things around you with cellular connectivity. The first edition of RePhone core is Xadow – GSM+BLE, this time we provided another 2 edition of RePhone core which with higher performance and lower power consumption, one of them is the RePhone Core 2G-AtmelSAMD21 v1.0
The RePhone Core 2G-AtmelSAMD21 v1.0 is a new Arduino compatible RePhone core 2G board, which is based on Atmel’s SAMD21 and SIM800H, Most features of RePhone Core 2G-AtmelSAMD21 v1.0 is the same as Xadow – GSM+BLE, such as offering rich range of communication protocols – GSM, GPRS, and Bluetooth, supporting quad-band 850/900/1800/1900Mz, and supporting 2G Nano SD card. But the solution of Atmel’s SAMD21 plus SIM800H has dropped power consumption a lot comparing to Xadow – GSM+BLE. If you are looking for a high-performance and low power consumption Rephone core to enchant the world, the this new RePhone core 2G module is the best choice.
We also provided a more economic version RePhone core 2G Atmel32u4, the only difference is the MCU. Click here to find it.
Note
  • The RePhone Core 2G-AtmelSAMD21 v1.0 is compatible with all the Xadow v2.0 except the Xadow 1.54 inch Touchscreen
  • Please connect a battery to the board if you want to use the GSM or GPRS function in case the power form USB is not enough and fail to communicate.
  • BAT Input Voltage: 3.4-4.2V
  • USB Input Voltage: 5V
  • Power Consumption: ~30mA@standby mode
  • ATSAMD21G18: Cortex-M0+, 48MHz, 256KB flash, 32KB SRAM
  • Nano SIM connector
  • Integrated Power Control System
  • Support AT Command
  • Support Bluetooth v3.0
  • Quad-band: 850/900/1800/1900Mz
  • Connector: 35 PIN Connector & 11 PIN Connector for Xadow Modules; JST 1.0 Connector for the battery
  • Interface: Analog Audio/I2C/SPI/UART/20*GPIO
  • Arduino compatible
  • Compatible with all Xadow 2.0 except the Xadow 1.54 inch Touchscreen
  • Working Temperature:-40 – 85℃
  • Size: 30*25mm
Dimensions 75mm x115mm x7.5mm
Weight G.W 8g
Battery Exclude
RePhone core 2G-AtmelSAMD21 1
HSCODE 8517703000
COO CHINA
RoHS 1
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    Good data transfer solution for IoT and embedded systems
    By
1 Item
Show per page
