PIR Motion sensor module
The PIR Motion sensor module is an automatic control module based on infrared technology. It adopts LHI788 probe, which has high sensitivity, high reliability, low voltage working mode and low power consumption.
- 10+: $4.20
The PIR Motion sensor module is an automatic control module based on infrared technology. It adopts LHI788 probe, which has high sensitivity, high reliability, low voltage working mode and low power consumption. It can be widely used in various types of automatic induction electrical equipment.
The PIR Motion Sensor Series includes several products that will meet your different needs:
Product | Measuring range (theoretical value) | Features |
Grove - PIR Motion Sensor | Max Distance:3-6m(3m by default) Angle:< 120° |
Measuring distance and holding time adjustable response speed:0.3s - 25s |
Grove-Adjustable PIR Motion Sensor | Max Distance:3-6m Angle:X=110° Y=90° |
Measuring distance and holding time adjustable |
Grove - mini PIR motion sensor | Max Distance:2-5m(2m by default) Angle:X=110° Y=90° |
Sensitivity adjustable Mini-size |
PIR Motion sensor module | Max Distance:3-7m Angle:< 120° |
Sensitivity & Delay time adjustable |
Grove - Digital PIR Motion Sensor | Max Distance:3-12m Angle:< 100° |
Mini-size Simple and intuitive |
Want to know more about how the PIR sensor works with Arduino and Raspberry pi, please click here to view the blog. If you need tutorials for operating the sensor, please click here to view the wiki.
Applications
Switch
Motion sensor
Thief-guarding system
Industrial automation
Hardware Overview
Specifications
Item | Value |
Input Voltage | DC 4.5V ~ 20V |
Static Current | <50uA |
Output Signal | 0V / 3V (Output high when motion detected) |
Sensing Range | 7 meters (120 degree cone) |
Delay time | 8s ~ 200s (adjustable) |
Operating Temperature | -15℃ ~ +70℃ |
Dimensions | 24mm*32mm*25mm(Height with lens) |
Weight | 6.6g |
item | value |
PIR Motion sensor module | 1 |
HSCODE | 9031900090 |
USHSCODE | 9026104000 |
UPC | 841454105039 |
EUHSCODE | 9013101000 |
COO | CHINA |
RoHS | 1 |
from order viewThis user did not leave any comments.
