the AI Hardware Partner
Toggle Nav
Loading...
Raspberry Pi 3B & 3B+ Arc Enclosure - Black
This Raspberry Pi Arc Case is a simple and stylish case designed to provide better protection for your Raspberry Pi. It comes in two pieces, base, and top cover made of ABS plastic with a smooth full gloss finish.
$9.95
Out of stock
  • 10+: $8.96
  • Strong, and durable ABS plastic for better protection
  • GPIO Ribbon Cable Slot to easily connect a 40-Pin GPIO cable
  • DSI, CSI and Access Slots for Camera/video connections
  • In-built Raspberry Pi camera seat for easy camera installation
  • Carefully arranged cutouts on the sides for easy access to I/O Ports
  • Modern and stylish curved design
  • RoHS Certified
The enclosure provides cutouts for the GPIO ribbon cable, USB, Ethernet, micro-SD card, HDMI, DSI and CSI connectors. Also, there are rubber feet and vents to ensure that the board gets proper cooling.
It also has a camera module mounting hole in order to mount your Pi camera on top of this case and use it conveniently in your projects!
Note
This product does not include a Raspberry Pi. However, if you want to buy one, please click here to explore!
Tip
We also offer a transparent version of this case, click here to learn more.
Dimensions
94mm x 63mm x 30mm / 3.7" x 2.5" x 1.2"
Parts List
1 x Raspberry Pi B+/2/3B & 3B+ Arc Enclosure - Black
4 x Rubber Feet
2 x Screws
Dimensions 0mm x0mm x0mm
Weight G.W 37g
Battery Exclude
HSCODE 3923100090
UPC 841454100195
COO CHINA
RoHS 1
