Loading...
Circumference 300m Wheel
This wheel tyre is made from special wear-resisting non-slip rubber and aluminum alloy wheel hub, can to ensure the long-term use of length accuracy effectively) Feature: Wearproof, strong and durable Specificati
$13.90
Out of stock
  • 10+: $12.51
  • 20+: $11.82
  • More
  • 50+: $11.12
  • Less
Feature:
  • Wearproof, strong and durable
Specification:
  • Circumference:300MM
  • Diameter:94mm
  • Thickness:14mm
  • Bore diameter:6MM
  • Material:Hub aluminum,tyre: wearproof rubber
Dimensions 0mm x0mm x0mm
Weight G.W 106g
Battery Exclude
HSCODE 8483409000
Documentations
Learn
