Loading...
Differential Gear Kit
A kind of rotation motion by one axi to become two, and it can be make different speed between the output shafts。 Almostly to be used on structrue of the automobile Feature: popural type 2 planetary gear good wear-resistance
$5.75
Out of stock
Feature:
  • popural type
  • 2 planetary gear
  • good wear-resistance
  • low niose
  • transmission smooth and steady
  • material: matel
Specification:
  • Tooth number(output axis gear):18 or 20。High:17.2mm,outside diameter:40mm,inside diameter:17.1mm
  • Tooth number(planetary gear):14 or 15,thickness:9mm,outside diameter:30mm,inside diameter12.3mm,shaft length:60mm
Dimensions 0mm x0mm x0mm
Weight G.W 215g
Battery Exclude
HSCODE 8483409000
Documentations
Learn
