Wio Link Starter Kit
Specially selected Grove set Plug-n-play with Grove connectors Friendly for starters Designed for IoT application development Cost-effective
$49.00
In stock
  • 10+: $44.10
  • 20+: $41.65
  • More
  • 50+: $39.20
  • Less
This kit is aimed at starters. The functional modules included in this kit are selected especially for a beginner which are frequently required modules, and very cost-effective. The most amazing part of this kit is the Wio Link development board which can be utilized for various devices: without much programming skill required. All the actions you want your modules performed and the flashing-code operation to Wio Link could be completed with taps in a mobile app. And you can send instructions to your devices over Internet at anywhere. So Wio Link will be a perfect utility to make things around smarter for everyone. Now let's enjoy being a maker.
  • Include common frequently-used environment-monitoring functional modules
  • Grove port interfaced, more practical function and less work
  • Completely easy to make things around you smarter and add fun to daily life.
  • Cost-effective
attention icon
Warning
The Wio IFTTT function is EOL. But Wio APP is available. You can use the API from Wio APP to read sensor status and control the actuator.
Dimensions 190mm x120mm x45mm
Weight G.W 260g
Battery Exclude
Grove - Button 1
Grove - Relay 1
Grove - Temp&Humi Sensor 1
Grove - Digital Light Sensor 1
Grove - WS2812 Waterproof LED Strip - 30 LEDs 1 meter 1
Grove - 3-Axis Digital Accelerometer(±1.5g) 1
Wio Link 1
Micro USB Cable - 48cm 1
ECCN 5A002.a.1
HSCODE 9023009000
USHSCODE 90230000
LED Sound Meter using Wio-Link and Node-Red
SeeedStudio Grove sound sensor and LED strip attached to Wio-Link being driven by a Node-Red flow.
ReSpeaker Smart Home
We use the ReSpeaker Core v2.0 and Wio Link to control a light and fan via IFTTT.
Wiki of Wio Link Starter Kit
Product Faqs
Sort by
