Loading...
Raspberry Pi Media Center Kit
Out-of-box OpenELEC preinstalled Raspberry Pi 2 supported Including WiFi USB Dongle HDMI CEC supported
$19.90
In stock
Raspberry Pi not included
It's an out-of-box media center kit based on Raspberry Pi.
Raspberry Pi is the perfect device for build home theater systems. This kit is compatible with Raspberry Pi Model B+/A+/2, and the SD card pre-installed OpenELEC for Pi 2(Of cause, you can re-burn OpenELEC for Pi Model B+/A+).
The Kit Contains:
  • 5V 2.1A Power Adapter(European version coming soon): 2.1A Power Adapter is the good choice for Pi 2.
  • Micro USB and HDMI Cable: There are a switch which USB cable contains is built-in, so you can turn on/off easily. And the HDMI cable is 1.5 meters length.
  • WiFi USB Adapter: Network devices, wire or wireless.
  • Transparent arc enclosure: A blister shell, easy to assemble
  • 16GB SD Card: pre-installed OpenELEC Media Center System, and a greater capacity to store more :)
FEATURES
  • Out-of-box
  • OpenELEC preinstalled
  • Raspberry Pi 2 supported
  • 16GB MicroSD
  • Including WiFi USB Dongle
  • HDMI CEC supported
PART LIST
  • 16GB MicroSD
  • Raspberry Pi 2 Arc Enclosure - Transparency
  • American Standard USB Wall Charger
  • USB to Micro Cable w/ Switch
  • 1.5M HDMI Male to Male Cable
  • WiFi USB Adapter(Realtek RTL8292cu)
DOCUMENTS
NOTE
Dimensions 200mm x130mm x70mm
Weight G.W 400g
Battery Exclude
HSCODE 8517709000
UPC 841454104438
ROHS 1
Documentations
Learn
