Loading...
Grove - Gas Sensor(MQ2) - Arduino Compatible
Rating:
100% of 100
Fast response Adjustable sensitivity Covers LPG, i-butane, methane, alcohol, Hydrogen etc Useful for gas leakage detecting Grove connector compatible
$6.90
Out of stock
  • 10+: $6.21
  • 20+: $5.87
  • More
  • 50+: $5.52
  • Less
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
The Grove - Gas Sensor(MQ2) module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, smoke and so on. Based on its fast response time. measurements can be taken as soon as possible. Also, the sensitivity can be adjusted by the potentiometer.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
  • Wide detecting scope
  • Stable and long lifetime
  • Fast response and High sensitivity
Documents
More information about the gas sensor, please refer to this manual.
Dimensions 130mm x90mm x32mm
Weight G.W 16g
Battery Exclude
Grove - Gas Sensor(MQ2) 1
Grove cable 1
HSCODE 9027900000
USHSCODE 90230000
UPC 841454108351
ROHS 1
Learn
Show environmental parameters such as temperature, humidity and air quality when people come by.
This project helps us to detect the leakage and presence of butane gas in the area around the device!
Generation of wood gas (fuel) using waste around us.
The best safety equipment for your Mother or Wife. A Must Watch!
Interesting and Easy latest projects during COVID-19. A Must Watch!
Android application monitoring system for GreenHouse, several sensors for reading data and send to application.
An indoor air quality monitoring system for detecting toxic gases.
Monitoring Industries using the power of the Internet and automation.
Octopod, a uniquely shaped full automation system that allows you to monitor your industry and keep security with AI and smart RFID locks.
How to create your own Arduino training platform for beginners to start learning Arduino programming.
Healthy indoor environments system of smart commercial buildings Using Masked Authenticated Messaging (MAM) of the IOTA protocol.
I have worked on MQ-2 gas sensor (FC-22) powered and interfaced it with an Arduino Uno.
If an accident or any gas or smoke leakage is detected, it notifies through call and through Blynk app.
A line follower bot which can detect gas leaks and high temperature in a typical household and raise an alarm.
The goal of this tutorial is to enable you to capture and send data to cloud from NodeMCU.
This project will demonstrate the real prototype of smart cities product including sensor data manipulation using Google Data Studio.
Arduino-based smart home hub allows you to control your devices remotely from outside and monitor your home environment from your phone.
A prototype for Smart Cities to enhance Environment Monitoring using MKR GSM1400 and Hologram.
We thought that in every house we could have a gas leak and consequently a fire so we have designed a project that delete this problem.
Air Quality Monitoring that uses the Intel Edison Compute Module, Amazon AWS, Visualization through Kibana, and drones!
Octopod, a uniquely shaped full home automation system that allows you to monitor your home and keep security with AI and smart RFID locks.
Wiki of Grove - Gas Sensor(MQ2)
  1. Rating
    100%
    By
  2. Rating
    100%
    Nice
    By
2 Item(s)
Show per page
