Loading...
Grove - Gas Sensor(MQ5)
Rating:
80% of 100
Fast response Adjustable sensitivity Detects LPG, natural gas, town gas etc. Useful for gas leakage detection Grove compatible interface
$7.90
Out of stock
  • 10+: $7.50
  • 20+: $7.25
  • More
  • 50+: $7.00
  • Less
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
The Grove - Gas Sensor(MQ5) module is useful for gas leakage detecting(in home and industry). It can detect LPG, natural gas, town gas and so on. Based on its fast response time. measurements can be taken as soon as possible. Also the sensitivity can be adjusted by the potentiometer.
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
Dimensions 130mm x90mm x20mm
Weight G.W 17g
Battery Exclude
Grove - Gas Sensor(MQ5) 1
Grove - cable 1
HSCODE 9027900000
USHSCODE 90230000
UPC 841454108337
ROHS 1
Learn
Intel Edison Gas Sensor System to Detect Biogas / LPG Leakage
PSoC 4: Natural Gas Leakage Alarm System for Kitchen Safety.
Using Wemos D1, GSM module, MQ5/MQ6 sensor and IoT platform (ThingsIO.AI). Here it will give a message on your phone also when fire detected.
Air Quality Monitoring that uses the Intel Edison Compute Module, Amazon AWS, Visualization through Kibana, and drones!
Testing the MQ Gas sensors
The Grove - Gas Sensor(MQ5) module is useful for gas leakage detection (in home and industry). It is suitable for detecting H2, LPG, CH4, CO, Alcohol. Due to its high sensitivity and fast response time, measurements can be taken as soon as possible.
  1. Rating
    40%
    Did not work
    By
  2. Rating
    100%
    By
2 Item(s)
Show per page
