Grove LED Bar v2.0
Rating:
100% of 100
10 Leds Arduino Library Easy-to-Use
$3.90
In stock
  • 10+: $3.55
  • 20+: $3.35
  • More
  • 50+: $3.20
  • Less
Grove – LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip. It can be used as a indicator for remaining battery life, voltage, water level, music volume or other values that require a gradient display. There are 10 LED bars in the LED bar graph: one red, one yellow, one light green, and the rest green. Demo code is available to get you up and running quickly. It lights up the LEDs sequentially from red to green, so the entire bar graph is lit up in the end. Want to go further? Go ahead and code your own effect.
  • Each LED segment can be controlled individually via code
  • Grove module
  • Plug-and-play
  • Can be cascaded for a larger display
  • Flexible power option, supports 3-5.5DC
  • Available demo code
Dimensions 40mm x20mm x18mm
Weight G.W 12g
Battery Exclude
Package Dimension 89mm x 140mm x 12mm
Grove - LED Bar V2.0 1
Grove - Cable 1
ECCN EAR99
HSCODE 8531200000
USHSCODE 8531200040
UPC 841454107293
ROHS 1
Grove LED Bar Controller with the Bean+
Learn the basics of using popular Grove components with the new LightBlue Bean+ to get started with building your own projects!
Grove LED Bar v2.0
Calliope Mini is equipped with two Grove connectors. In this project, I want to explore, how to talk to these Seeed Grove parts.
The Internet Of Led Wall!
DIY a very cool Led wall with wio node and Led Bar.
Grove - LED Bar
Grove – LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip. It can be used as an indicator for remaining battery life, voltage, water level, music volume or other values that require a gradient display.
Customer Reviews
  1.
    Rating
    100%
    Works as described.
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
  • Question by: admin on 2018-12-18 02:24:12
    Hi there, please let us know more detail about the issue. thanks.
    Answer by: admin on 2018-12-18 02:24:12
