Grove - Light Sensor v1.2
Rating:
96% of 100
Easy to use since it is interfaced with Grove port. High reliability and sensibility. Small footprint Recognize wider spectrum.
$2.90
In stock
  • 10+: $2.70
  • 20+: $2.50
  • More
  • 50+: $2.30
  • Less
As an updated version of Grove - Light Sensor 1.0, the Grove - Light Sensor v1.2 is also aimed at measuring light levels, however with higher reliability and sensibility. It is an analog module and outputs various electrical signals which can be converted to different ranges (It depends on the Analog-to-Digital-Converter on your controller board. For example, it can output 0-255 for an 8-bit ADC). It integrates a high-sensitive and reliable phototriode, and just like other grove modules, it is interfaced with Grove port which can save you a lot of work in the wiring.
  • Easy to use since it is interfaced with Grove port.
  • High reliability and sensibility.
  • Small footprint
  • Recognize wider spectrum.
Dimensions 20mm x20mm x18mm
Weight G.W 8g
Battery Exclude
Operating voltage(V) 3-5 V
Operating current(mA) 0.5-3 mA
Response time 20 ~ 30 milliseconds
Peak Wavelength 540 nm
Phototriode GL5528(datasheet)
Grove - Light Sensor V1.2 1
Grove Cable 1
ECCN EAR99
HSCODE 9031809090
USHSCODE 90230000
UPC 841454118992
MT3620 Mini Dev Board
This is the wiki page for this product, which will show you how to use the product, as well as details about the software and hardware.
The Environment Cube! Know the Land Beneath You using Sigfox
A cube with all the necessary sensors, suitable for a wide range of applications like agriculture, monitoring, ,etc.
Grove - Introduction in a Light Sensor
I would like to share my first steps with the Grove 'plug & play' components. This is primarily a Light Sensor.
Lección 12 : Módulo sensor de luz de Grove.
En esta lección vamos a aprender a conectar y programar el módulo sensor de luz de GROVE.Thanks Javier Martinez provide this lesson for introduction to Seeeduino with Grove Starter Kit.
Lesson 12 : Light sensor Grove module.
In this lesson you will learn how to connect and program the light sensor grove module.Thanks Javier Martinez provide this lesson for introduction to Seeeduino with Grove Starter Kit.
The Grove - Light sensor integrates a photo-resistor(light dependent resistor) to detect the intensity of light. The resistance of photo-resistor decreases when the intensity of light increases. A dual OpAmp chip LM358 on board produces voltage correspond
Customer Reviews
  1.
    Rating
    80%
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    100%
    Review by
    Posted on
  4.
    Rating
    100%
    Review by
    Posted on
  5.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
  • When will these be back in stock? Is there a way to be notified when they are back in stock?
    Question by: Scott Klein on 2019-02-18 01:53:42
    Hi Scott, It is available now. We feel your pain, the in stock notification function will be available soon. Regards
    Answer by: admin on 2019-02-28 05:49:42
  • Question by: admin on 2018-12-18 02:21:03
    Hi, I've bought this sensor. I'm reading the analog values of the sensor and the max read is 738. Is it possible to have a table where you map analog values with lux? Because at the following link http://wiki.seeedstudio.com/Grove-Digital_Light_Sensor/ I did not find anything about it Regards
    Answer by: admin on 2018-12-18 02:21:03
Bundle Sales
  1. Grove - Light Sensor v1.2
  2. +
  3. Grove - Sound Sensor
  4. +
  5. Grove - Red LED
  6. +
  7. Grove - Temperature&Humidity Sensor (SHT31)
  8. +
  9. GrovePi Zero(GrovePi0)
  10. +
  11. Grove - LCD RGB Backlight
  12. +
  13. Grove - Buzzer
Total price: $0.00
