Loading...
Grove - RGB LED Stick (10 - WS2813 Mini)
Grove - RGB LED Stick (10 - WS2813 Mini), full color
$4.90
Out of stock
  • 10+: $4.45
  • 20+: $4.15
  • More
  • 50+: $3.95
  • Less
We integrated 10 full-color RGB LEDs on this stick, with only one signal pin you can control all 10 LEDs easily. All the LEDs are WS2813 Mini, which is an intelligent control and high cost-effective LED. What's more, the WS2813 support signal break-point continuous transmission, which means you can continue to use other leds with one led be broken.
You can use this little stick to create hundreds and thousands of light effects. We hope it will bring you a lot of fun.
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
  • WS2813B IC, 3535 LED
  • Intelligent Reverse-connection protection.
  • The gray levels of each pixel are of 256, which achieves “256*256*256=16777216” full-color display.
  • The refresh frequency reaches to 2KHz.
  • Serial cascade interface, data receiving and decoding depend on just one signal line.
  • Dual-signal wires version, signal break-point continuous transmission.
Signal break-point continuous transmission
As long as not two or more adjacent LEDs are broken, the remaining LEDs will be able to work normally.
Typical application
  • Christmas decoration
  • Illumination
  • Toys
Pin out
Dimension
Grove - RGB LED Stick (10 - WS2813 Mini) 1
Grove Cable 1
HSCODE 9405409000
USHSCODE 8473305100
UPC
Learn
This is the wiki page for this product, which will show you how to use the product, as well as details about the software and hardware.
