Grove - I2C High Accuracy Temp&Humi Sensor (SHT35)
Rating:
100% of 100
Grove - I2C High Accuracy Temp&Humi Sensor(SHT35), temperature, humidity, temperature sensor, humidity sensor, Temperature&Humidity, Temperature and Humidity
$13.90
In stock
  • 10+: $12.50
  • 20+: $11.80
  • More
  • 50+: $10.90
  • Less
Grove - I2C High Accuracy Temp&Humi Sensor(SHT35) is based on SHT3x-DIS, which is the next generation of Sensirion’s temperature and humidity sensors. It builds on a new CMOSens® sensor chip that is at the heart of Sensirion’s new humidity and temperature platform. The SHT3x-DIS has increased intelligence, reliability and improved accuracy specifications compared to its predecessor. Its functionality includes enhanced signal processing, two distinctive and user selectable I2C addresses and communication speeds of up to 1 MHz.
  • High accuracy of ±1.5 %RH and ±0.1 °C
  • Fully calibrated, linearized, and temperature compensated digital output
  • I2C Interface with communication speeds up to 1MHz and two user selectable addresses
  • Very fast start-up and measurement time
Typical Applications
  • Industrial Freezers and Refrigerators
  • Food Processing
  • Personal Computers and Servers
  • PC Peripherals
  • Consumer Electronics
  • Handheld/Portable Devices
Pin Out
Dimensions 20mm x40mm x6mm
Weight G.W 3.1g
Battery Exclude
Operating Voltage 3.3V / 5V
Specified Temperature Range -40°C to +125°C
Temperature Resolution 0.01°C
Temperature Accuracy Tolerance ±0.1 °C
Specified Humidity Range 0%RH to +100%RH
Humidity Resolution 0.01%RH
Humidity Accuracy Tolerance ±1.5 %RH
Interface I2C
I2C Address 0x45(default) / 0x44(optional)
Grove - I2C High Accuracy Temp&Humi Sensor(SHT35) 1
Grove Cable 1
ECCN EAR99
HSCODE 9025900090
USHSCODE 90230000
UPC 841454121305
This is the wiki page for this product, which will show you how to use the product, as well as details about the software and hardware.
Product Faqs
Sort by
