Seeeduino Mega(ATmega2560)
Rating:
87% of 100
Built around ATmega 2560 @ 16MHz Massive GPIOs: 70 digital I/Os, 16 Analog input and 4 UART etc Small form factor, 30% smaller than Arduino Mega 3.3V and 5V dual mode Can be powered through a battery or through a AC to DC adaptor
$43.00
In stock
  • 10+: $38.70
  • 20+: $36.55
  • More
  • 50+: $34.40
  • Less
Seeeduino Mega is a powerful micro-controller derived from Arduino Mega. It features ATmega2560 processor which brings a large number of I/O pins, as much as 70 digital I/O, 16 analog inputs, 14 PWM, and 4 hardware serial ports. Compared to Arduino Mega, we shrunk the volume of Arduino Mega by at least 30% and made it 100% compatible with Seeed Shield products. And as a member of Seeeduino series, Seeeduino Mega inherits deliberate details from Seeeduino, like selectable operating voltage(3.3V/5V), right angle reset button, and so on.
  • ATmega 2560 @ 16MHz
  • Selectable 5V/3.3V operation
  • 70 Digital IO
  • 16 Analog inputs
  • 14 PWM outputs
  • 4 Hardware serial ports (UART)
  • Compatible with most Arduino Duemilanove and Diecimila Shields
  • Small form factor, 30% smaller than Arduino Mega
  • Easy to program, no additional hardware is required to load firmware – just plug to a USB port and you’re good to go.
  • ICSP Header
  • Can be powered through a battery or through a AC to DC adaptor
Dimensions 115mm x75mm x25mm
Weight G.W 54g
Battery Exclude
Seeeduino Mega 1
ECCN EAR99
HSCODE 8471504090
USHSCODE 8471500150
UPC 841454103394
Seeeduino Mega
Wiki of Seeeduino Mega
Product Faqs
Sort by
