easyRadio 433MHZ USB Transmit & Receive for Raspberry Pi
SKU 317990016
82.00
DISCONTINUED
Utilising proprietary LPRS easyRadio technology operating in the 434MHz Industrial Scientific & Medical (ISM) bands the Connect2Pi USB ‘dongle’ provides a simple wireless bridge between Raspberry Pi (Pi2Pi), a Raspberry Pi and a PC or any other device that supports USB serial communications.
These devices provide considerably greater range and less power consumption than similar WiFi or Bluetooth dongles operating in the overcrowded 2.4GHz bands.
Frequency, bandwidth, power output and data rate can (optionally) be configured to allow multiple devices to communicate free from interference from each other and any other RF devices.
FEATURES
  • LPRS easyRadio RF Transceiver technology, Bi-directional link, no RF protocol software required
  • USB Connection, Plug & Play operation, appears as a Com port
  • Low current consumption, Can be powered directly from Raspberry Pi
  • Integral SMA Antenna connector, Allows use of extension for optimal antenna position
  • FTDI FT232 USB IC, Linux & Windows drivers available (see below)
  • Transmit & Receive LEDs, Diagnostics
  • Configurable RF parameters (optional), Fine tune for optimum performance
  • Up to 180 Bytes per packet, Ideal for Sense & Control applications
  • Built-in Temperature Sensor, Usable by host program
Technical Details
Dimensions100mm x 70mm x 7.50mm
WeightG.W 20g
BatteryExclude
RF USB Dongle1
Antenna1
ECCNNot Available
HSCODE8517691090
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Is there a matching receiver?
on Dec 06,2017
Reply upvote ()
Hi Richard~ This one is a transceiver & transmitter Modules.You can use two of this module to set up a connection net. Regards
on Dec 08,2017 11:36 AM
Reply upvote ()
Reply
    View History
    SKU 317990016
    $82.00
    DISCONTINUED
    $82.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
