GoGo Board Kit
The GoGo Board is an open-source device for educational robotics, scientific experiments, physical computing and automation
$55.00
In stock
The GoGo Board is an open-source device for educational robotics, scientific experiments, physical computing and automation. Designed for children ages 9 and older, the GoGo Board allows a child to focus on what he or she wants to invent without having to first learn the low-level details about electronics. The board works with most analog Grove sensors allowing the use of hundreds of readily available sensors from SEEED. The built-in screen can be used to show live sensor values without needing a computer. The GoGo Board controls 4 motors, which can be a mix of DC and servo types. A visual programming environment based on Google Blockly makes programming more accessible for beginners. The GoGo Board is an HID device requiring no driver installation, it is completely plug and play on both Windows and Macs. Just plug in the USB cable and you are ready to go. The GoGo Board also works with the Raspberry Pi allowing for projects that require more capable peripherals and computation.
  • Visual programming language based on Google Blockly and designed for beginners. Can be programmed using text as well.
  • Eight sensor ports. Works with most existing analog Grove sensors.
  • Four output ports. Works with DC and Servo motors
  • HID device. No driver installation. Automatic detection when plugged in on Windows and Macs.
  • Works with the Raspberry Pi for smartphone integration, vision, data logging and many other additional functionalities.
  • Built-in display, Infrared Receiver, I2C extension port
Dimensions 232mm x172mm x70mm
Weight G.W 631g
Battery Exclude
Analog Input 8 ports
Output 4 bi-directional ports with status LEDs
Communication 1xUSB, 1xUART, 2xI2C, 1xRaspberry Pi GPIO, Infrared Receiver
Display 4 digit 7-segment
Power Consumption 5V @ 100 - 1,000 mA depending on the load
Power Source Micro USB connector, Terminal block
GoGo Board 1
Sensor Set 1
Servo Motor (EMAX 9g ES08A High Sensitive Mini Servo SKU 108090000) 1
micro USB cable (48cm SKU 321010007) 1
IR remote control 1
Grove Cables (Universal 4 Pin 30cm) 10
JST cables 4
Wheels 2
HSCODE 9023900090
UPC 841454118893
Product Faqs
Sort by
